Valve spring breakage
Did a compression check and in #5 got a reading of "0"
Leak down provided a nice breeze out the exhaust pipe.
Pulled the valve cover and found this:
$3.48 for a new spring and car back to running great.
YOu have a harmonic issue. All of the springs have seen this so you need to replace all of them.
I know I have some decisions to make about the engine & maintenance (ie. while you are at it) and was hoping to make those during the winter storage. I really posted a FWIW so some owners can see what can happen. Engine has 102,000 miles.
Thanks again.
As you know I too broke a value spring on my 78 L-82 in 1985 cruising down the highway, just like you. Drove it home for about 10 miles running like crap before I pulled the valve cover and discovered a broken spring just like yours-looked exactly the same-probably inferior manufacturing/defect. Changed that one spring just like you and have been driving it ever since-66,000 miles now/27 years later-no issues! I did change the rockers to comp cams roller tipped 1.5's in the early 90's when i changed all the valve stem seals along with 16 new pushrods using all the rest of the OEM springs. Probably should have changed all the other 15 springs back then but did not since I figured it was a one off. My experience has been that the secondary spring will prevent the valve from falling into the cylinder as long as you are not revving the crap out of the motor!
