Hello all, I am trying to get my factory temp gauge working. I removed my aftermarket probe from passenger side head was going to put on driver's side but the plug in stripped out when trying to remove it. So I moved the am probe to the intake by the tstat and put my factory replacement in passenger head which leads me to my questions:
1.since I've moved am probe temp reads cooler, could this be from header heat difference? Should I be worried?
2. The replacement probe I got from corvette central is reading to ground. Is this correct?
The sender to ground should read ohms and if it is working correctly here is a chart for the 1968-1974 gauges.
Can the location switch make a difference.. sure it can. The heat on top the engie is not going to be as hot as by your header. How much??? It really shouldn't make a huge difference. As you can so by the chart below the hotter the sender the smaller the change at the high end.
Thanks WC
I hooked up my new sender but no change at gauge. I put my volt meter on 12VDC POS Lead to green wire from gauge Neg lead to sender terminal. Measured 3.4 VDC
I'm not sure what you are doing and maybe I'm lost... I read you post above again and you removed an aftermarket sender... The wires that ran to this sender are what color? Green and Green?
So.. I think you need to isolate the original green single wire for the dash unit..
The sender I have is the 6490453. The aftermarket is a gauge/sender combo. No electric wires just a solid bare copper wire with probe attached. I was going to use two gauges until I new the factory gauge was reading correctly. When I get home I will try to upload pics.
right click on the picture.. then select copy picture ulr... that is what you post in the picture box.. just delete the http that will be in the box first.
Just hang in there, we'll get it working.. but the sender you gave me the part number for was the two terminal sender.
what water pump do you have ?what pulley sizes are you using ?what air dam are you using on the bottom of the radiator ?is all the air bleed out of the coolant system.
As far as the temp sender, I. Grounded the green wire to temp gauge and needle did not change.
So I pulled gauge out and ran a jumper from ground terminal to green wire terminal and needle moved and stayed above 210. Car hasn't been running, just had key in on position.
I know the green wire is making it all the way out to engine bay because I can see a difference of potential when I measure green wire to ground.
