Heat and AC Troubles
Old Sep 16, 2012 | 11:38 PM
Mariana's Avatar
Mariana
Default Heat and AC Troubles
I have posted about this before, and gave up for a little since its been 90+ here in Tennessee.
while attempting to reattach the wire harness for the heat/ac I realized I was missing a lot of pigtails. the previous really cropped the ball. so I started by connecting the blower motor. NO WORKEE! I ran a hot wire from the fuse box and a separate ground...no workee. the "T" shaped pigtail is there. I have no compressor (YES, the car is supposed to have AC). I heard that id the Climate Control Unit (interior) is bad then it wont work at all. IT THAT TRUE. Really, I dont even think you guys can help, but 2 (multiple) heads are better that one, and I may be forgetting.not thinking in the right direction. I used the DR. Rebuild wiring Diagram.
I NEED HELPFUL INPUT and IDEAS.
but I checked alot of sites for the missing pigtails and I cannot find 4 of them. Does anybody have any old harnesses laying around?
Old Sep 17, 2012 | 10:08 AM
lvmyvt76's Avatar
lvmyvt76
sounds like you need a new dash wiring harness, that way you will have everything wired right.
Old Sep 17, 2012 | 10:18 AM
Mariana's Avatar
Mariana
Yeah.....thats what is looking like. But still, what the hell is is going on with the blower motor at least. I removed the relay that has the spring/coils from the box and everything looks good. And the doors and cables work. and fuses are ok, not blown or nothing. Im gonna attach some wire terminals tomporary so I can get it operational then get the harness. i need to find the problem first.
To Heat and AC Troubles
