Suspension / Spring Advice for 73 Vert
I read through a lot of posts including the ones from Wilcox on the bushing sets. From what I read I ordered the rubber ones. Still second guess myself on that every now and then but I'm sure I'll be happy with the rubber. By the way... What shocks are you using with that spring?
Is this the spring you're using? http://willcoxcorvette.com/product_i...ducts_id=12144
Since you are starting to tear down the rear suspension, lets start there. I think most people do not give enough attention to the rear suspension since it can be a pain to work on.
You may want to consider:
Replacing those rubber bushings at the front of the control arm with steel. Help reduce the rear end coming around (trailing throttle oversteer) when you get on that 383 motor.
Replace all emergency brake shoes and springs with stainless steel.
Replace those rubber brake hoses with braided steel lines
New camber arms
Swap from regular shims to stainless steel.
New grade 8 bolts all around
New bearings for reliability
New shocks
Of course you want the arm to look pretty, so get all the rust off and paint it.
As far as springs, I am partial to the F-41 suspension. Great handling, not too bad for the street. I spoke to Dick Guldstrand (he actually answers the phone himself!) and he convinced me to purchase a multi-leaf spring over a composite spring
New camber arms
New shocks
Still confused over the spring though. I dont mind leaving the one thats on it now on the car but maybe just a new set of shocks would do.
Front:
1 1/8 oem bar with poly bushings-end links and mounting bushings
550 front springs 1 inch shorter than stock
Poly upper and lower control arm bushings
Custom rebuilt/blue printed steering box by Gary ramadei
Speedirect spreader bar
Blistein HD shocks with poly bushings
255/45/17 ZR summer only ultra high performance tires
Rear:
360 mono spring with poly cushings
Competition adjustable strut rods with heim joints
3/4 inch oem type sway bar with poly bushings
Bilstein Sport shocks
255/50/17 ZR TIRES
Do not use KYB gas a just mono tube shocks with a composite spring- they do not provide adequate damping with a fiberglass spring. With a 360 spring I originally had Bilstein hd's and switched to the Bilstein Sports for better rebound control. The kyb may work better with a 300 and lower spring. The car is not raced, only street driven!
Hope this helps!
Best of luck
Rodney
I’m just giving another point of view. Everyone has to set-up and adjust their own car to the way they want it to be and the handle.
