1978 automaic will not shift into 3rd gear.
Old Sep 20, 2012 | 02:19 PM
raysc3's Avatar
raysc3
3rd Gear
Default 1978 automaic will not shift into 3rd gear.
the car will go into frist and second with know trouble but will not shift into third, has anyone had this trouble before. 1978 350
Old Sep 20, 2012 | 02:23 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
A slight clarification: will not shift up to third when driving?
Old Sep 20, 2012 | 02:47 PM
MelWff's Avatar
MelWff
Check the transmission throttle cable adjustment.
Old Sep 20, 2012 | 04:02 PM
1986coupe's Avatar
1986coupe
Check fluid level.
Check to make sure that the vacuum connection at the transmission isn't leaking.
Old Sep 21, 2012 | 10:50 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by 1986coupe
Check fluid level...Check to make sure that the vacuum connection at the transmission isn't leaking.
I agree with both once we find out what's going on.
Old Sep 21, 2012 | 10:59 PM
Doug1's Avatar
Doug1
Check fluid level.
check vacuum where it hooks to carb as well. it the one very close to distributor if you aren't sure
Old Sep 22, 2012 | 09:44 PM
ajrothm's Avatar
ajrothm
Spool valve in the governor may be stuck. My T400 did the same thing once. Pull the governor out and pull it apart, clean the spool valve with Emery cloth and carb cleaner, then lube/reassemble.. OR buy a new governor from a tranny shop for about $25. This is what I did.
To 1978 automaic will not shift into 3rd gear.
