HEI pics needed!!
Old Jun 2, 2002 | 10:14 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Default HEI pics needed!!
I took the car out for a spin today and found it popping throught the exhaust when I start to accelerate. I want to eliminate any stupid problems first. I have never dealt with the gm HEI units before and want to make sure I ran my wires right. Does anyone have a picture of the HEI distributor cap and what wires go where??
Mark B.
Old Jun 2, 2002 | 10:32 PM
mg62's Avatar
mg62
Default Re: HEI pics needed!! (Sigforty)
Mark, dunno if this will be any help to you, but here's the pic of my ZZ4 installation, with the HEI distributor.
Old Jun 2, 2002 | 11:17 PM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: HEI pics needed!! (mg62)
just remember firing order is 1 8 4 3 6 5 7 2 clockwise
Old Jun 3, 2002 | 05:02 PM
Sigforty's Avatar
Sigforty
Default Re: HEI pics needed!! (Ed T)
I would really like some pics if possible. I will send an email today once I get off of work.
Mark B.
Old Jun 3, 2002 | 05:28 PM
Pete79L82's Avatar
Pete79L82
The 3 wire plug that comes from inside the distributor (pick-up coil) goes to the terminals closes to the cap. The brown wire is for the tach. The pink wire is the 12v source from the ignition switch. If you converted from a point system the pink wire must run all the way to the ignition switch and be a minimum of 14ga with no resistors in it. If you just spliced it onto your original 12v wire that went to your coil you will not have enough amperage and will get a miss at higher RPM's.
Old Jun 3, 2002 | 05:34 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Here is a drawing -- hope it helps.
Old Jun 3, 2002 | 06:12 PM
Sigforty's Avatar
Sigforty
Default Re: HEI pics needed!! (BSeery)
Perfect!! I think I have everything off a little. Looks to me like the 8 you are showing is my number 1 on the cap. I believe I have the firing order right, but am off on the cap placement by 1 cylinder.
Mark B.
Old Jun 3, 2002 | 06:27 PM
Fevre's Avatar
Fevre
Does that matter on a HEI system? I know it doesn't matter on a points sytsem just as long as you have them in the correct firing order.
Old Jun 3, 2002 | 06:38 PM
Pete79L82's Avatar
Pete79L82
Default Re: HEI pics needed!! (Fevre)
If you had all the wires off by one position the car would not run and you would not be able to set timing. On my car #1 is at the position of #8 on bseery's diagram. But it doesn't matter as long as the firing order is correct and the rotor is point to #1 plug wire when the timing mark is correct.
[Modified by Pete79L82, 4:39 PM 6/3/2002]
To HEI pics needed!!
