front suspension ball joint troubleshooting
Old Sep 25, 2012 | 03:19 PM
wolflt1's Avatar
wolflt1
Default front suspension ball joint troubleshooting
hi guys,
is there a way to troubleshoot the front suspension ball joints?
there is a lot of noise from the right side when driving.
i thought that maybe the wheel bearings are shot.
but it also seems that the front right tire is hitting the outer fender. the wheel has a lot more camber than before.
thanks for the help.
Old Sep 25, 2012 | 04:09 PM
MelWff's Avatar
MelWff
check the shims between the upper control arm and the frame, they probably fell out.
Old Sep 25, 2012 | 09:47 PM
doctorgene's Avatar
doctorgene
Yes Sir; Go to ( moogproblemsolver.com ) They tell you about any front end problems & how to find the problem. Have a great day. Gene
Old Sep 26, 2012 | 03:04 AM
wolflt1's Avatar
wolflt1
shims are all there with every tight between the upper arms and chassis frame.
thanks for the ball joint link
Old Sep 26, 2012 | 03:20 PM
wolflt1's Avatar
wolflt1
well, took off the wheel today and found that the outer bearing had completely disintegrated. probably torqued too tight.
To front suspension ball joint troubleshooting
