Question re: Rick Taylor Six-Link
Old Jun 3, 2002 | 02:07 PM
Kevin Mason's Avatar
Kevin Mason
Default Question re: Rick Taylor Six-Link
Will the Rick Taylor six-link set up work with offset trailing arms?
If no, does Mr. Taylor make a version which does work?
Old Jun 3, 2002 | 02:27 PM
norvalwilhelm's Avatar
norvalwilhelm
Default Re: Question re: Rick Taylor Six-Link (Kevin Mason)
I don't know Rick Taylor's 6 link but the location of the pumper pad is in the same location as stock so anything that bolts or welds to this pad will work weather the trailing arms are offset of not. With offset trailing arms you still use the same 1/2 shafts, the track width is the same so Yes any 6 link that works with the stock trailing arms should work with offset.
This is only a guess but makes sense to me.
Old Jun 3, 2002 | 03:05 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Who's Rick Taylor and how do I contact him? What is he selling the kit for?
Old Jun 3, 2002 | 10:12 PM
Stingy74's Avatar
Stingy74
Norval is correct, the mounting pad on the trailing arm will be in the same location as stock.
[Modified by Stingy74, 11:51 PM 6/3/2002]
To Question re: Rick Taylor Six-Link
