TH400 rebuild
Old Sep 29, 2012 | 06:56 PM
Mariana's Avatar
Mariana
Default TH400 rebuild
Before I rebuild this tranny can someone answer a question for me?
I changed the carb from a 750cfm to 600cfm, could that change cause a vacuum problem creating bad tranny performance?
I was going down the highway and it wouldnt shift up to 3rd...just a whining (but still moving). I got home and changed the fluid and filter (clogged) and modulator. There were metal shavings which I was told is normal. The next morning the car ran fine going to work. At lunch I drove around the corner and it whined and did not move. I pulled over and it moved again, but slow. I got to a light and it stopped again. I pulled over and waited 15 min, pulled off just fine. WTH. I have since got a rebuild kit, and ready to do work. But something doesn't seem right.
I have a mild cam and the headlights never worked. I did a vac test and it was about 10-12hg before the swap. I am going put to test it now, but would the carb make that much of a difference.
Old Sep 29, 2012 | 07:17 PM
Mariana's Avatar
Mariana
I guess a NEVERMIND is appropriate. Vacuum is still 10-11. low enough. Im just gonna rebuild.
Any tips, tricks, or advice on a TH400 rebuild?
Old Sep 29, 2012 | 08:05 PM
Roco71's Avatar
Roco71
Mine wines when stopped or at idle or very slow driving then stops once I start moving. I am wondering what next.
Old Sep 29, 2012 | 08:55 PM
Indiancreek's Avatar
Indiancreek
Sometimes a converter will whine when the fins start hitting each other. That's a sign you are about ready for a rebuild, as the shavings make their way through the tranny and make a mess of lip seals and bushings. Causing a pressure drop and clutch pack slipping.
Old Sep 29, 2012 | 09:00 PM
garygnu's Avatar
garygnu
thats low vacuum ,which mite require a different vacuum modulator.
Old Sep 29, 2012 | 10:42 PM
Roco71's Avatar
Roco71
All good to know. I thought about the converter less than 200 miles on it. Vacuum is something to look into.
Old Sep 30, 2012 | 12:42 AM
Indiancreek
Did you put fluid in the converter before the indtsll. If not that will kill'em quick sometimes.
Old Sep 30, 2012 | 09:14 AM
Roco71's Avatar
Roco71
I probably should start another thread as I think I am high jacking the OP thread. But yes a full quart fill and changed fluid and filter after a couple 100 miles. No metal shavings. Whines in gear only.
To TH400 rebuild
