Will oil deteriorate wiring insulation?
Old Oct 1, 2012 | 10:20 PM
1955pirate's Avatar
1955pirate
Default Will oil deteriorate wiring insulation?
In another thread I related how the line feeding the oil pressure gauge in my '69 had ruptured. The line has been blocked at the engine until I get it into the shop. Obviously, oil sprayed all over under the dash/instrument consoles and is still dripping down onto the floor of the car. I removed the carpets which will be replaced. My question: will the oil cause deterioration of the wiring or other components. Before replacing carpets I am going to clean, as best I can, the oil on electronic components.
Old Oct 1, 2012 | 10:32 PM
Doug1's Avatar
Doug1
I've never seen oil eat up insulation. As far as components, if they are working ok right now, I think you'll be fine.
Old Oct 1, 2012 | 10:58 PM
1955pirate's Avatar
1955pirate
Default oil and wiring
That was kind of what I was thinking, Doug. I am definitely going to wait a while b4 I replace the carpeting. Had planned on doing that sometime before next driving season anyway. The car will be going in for a paint job (another thread talked about the sob(s) that keyed both sides this summer) but I will have the oil pressure line and a couple of other mechanical projects done before going into the paint shop.
Old Oct 2, 2012 | 10:43 AM
71 f/w driver's Avatar
71 f/w driver
Oil will seep into the connectors at the gauges and cause them not to work. Happened to me. So, make sure you clean the oil off all connectors. My 2 cents.
Mike
Old Oct 2, 2012 | 12:31 PM
wcsinx's Avatar
wcsinx
It can, yes. But usually that only happens with chronic exposure over the course of years. I wouldn't be too concerned with one incident. But definitely get back there and clean everything off.
Old Oct 2, 2012 | 08:47 PM
DC3's Avatar
DC3
You can use electronic parts cleaner to safely clean the oil from the wires, connections, and/or gauges.
Here's one I've used and like: http://www.amazon.com/CRC-05101-QD-Electronic-Cleaner/dp/B000CCMLD0/ref=sr_1_2?s=automotive&ie=UTF8&qid=1349 225092&sr=1-2&keywords=crc+electronic+parts+cleane r
You should be able to find it locally at one of the parts stores.
DC
Old Oct 2, 2012 | 10:25 PM
Doug1's Avatar
Doug1
oh man, your one of the people that this has happened to? man, i'm sorry, I've never had this happen to me(yet), but I've seen cars that I knew at one time must have been just beautiful, have key scratches up and down the doors and fenders. sad as hell, does some poor jealous ******* gain some kind of satisfaction from defacing the fruits of someone else's labor?
To Will oil deteriorate wiring insulation?
