WTD BB power steering kit advice
Old Oct 1, 2012 | 10:28 PM
Vetterbegood's Avatar
Vetterbegood
Default WTD BB power steering kit advice
I have a 70 454 Vette, can anyone recommend a source and anyexperience with converting it's manual to power steering ?
Thanks, Keith
Old Oct 1, 2012 | 11:17 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I did the Borgeson conversion. It is a modern box that eliminates all the hokey PS rams and leaks etc. The road feel is great...much better than stock.
I did an article on it for Corvette Enthusiast magazine and if you seach the C-3 and C-2 Forums you'll find lots of info and pics.
JIM
Old Oct 2, 2012 | 02:38 AM
oldalaskaman's Avatar
oldalaskaman
amen
Old Oct 2, 2012 | 01:19 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
If you want the stock power assisted steering, purchase a kit from the aftermarket providers, purchase the assembly instruction manual (AIM) for your model year, and follow the assembly diagrams for the stock system.
Stock system is bolt up. Other than hand tools, you will need a pitman arm puller.
Old Oct 3, 2012 | 01:03 AM
aussiejohn's Avatar
aussiejohn
Default Go Borgeson!
JIM
I have a Borgeson box on my '74 coupe and factory PS on my '74 'vert and the difference is quite noticeable. Unless you're an **** NCRS type, then ditch the factory box and fit a Borgeson. Call Jeff, Barbara or Gil at Borgeson 1-860-482-8283 or www.borgeson.com.
Products are proudly made in the USA and the complete set-up shouldn't cost more than a grand.
Good luck!
Regards from Down Under.
aussiejohn
Old Oct 3, 2012 | 02:39 AM
oldalaskaman
amen ,same money ,better peace of mind
Old Oct 3, 2012 | 08:08 AM
bashcraft's Avatar
bashcraft
I'm not seeing a kit to convert from manual steering to power with a big block on the Borgeson site. Only for a small block.
Old Oct 3, 2012 | 08:40 AM
oldalaskaman
thats an excellent point.
Old Oct 3, 2012 | 08:55 AM
aussiejohn's Avatar
aussiejohn
Default Call Borgeson.
I'm pretty sure that it will fit if you have a standard exhaust manifold. If headers are fitted and they clear the standard box, they should clear the Borgeson box. It's no wider than stock, just a bit "longer."
aussiejohn
Old Oct 3, 2012 | 09:07 AM
bashcraft's Avatar
bashcraft
aussiejohn
It specifically says SBC with no mention of big block like they do with the other kits. It could be that they don't have a bracket to mount the pump to a big block.
Old Oct 3, 2012 | 09:14 AM
oldalaskaman
I would call them, they dont provide a new pump, you are recommended to either rebuild or buy a new one. your oe pump will work fine as far as fit. I'm sure aussiejohn is correct and the only issue is the width of the bbc
btw, very nice folks ,answer phones and give good answers
Old Oct 3, 2012 | 09:25 AM
bashcraft's Avatar
bashcraft
The kit is for manual to power conversion, so there is no OE pump and they do supply a new one with a bracket, but only for a small block.
Old Oct 3, 2012 | 09:27 AM
oldalaskaman
I missed that, many thanks, a place to get a bracket would be alan grove, I converted all my brackets to those and am a happy camper
Old Oct 3, 2012 | 09:55 AM
bashcraft's Avatar
bashcraft
Who is alan grove?
Old Oct 3, 2012 | 10:00 AM
oldalaskaman
http://www.google.com/url?sa=t&rct=j...Dfl-JxTNx8UKhA
the web site page looks , home made, but the products are excellent, I converted all by brackets to them when I upgraded my a/c to the aftermarket, hope this helps
Old Oct 3, 2012 | 10:15 AM
bashcraft's Avatar
bashcraft
Thanks for the link. It looks like they have what I need.
Old Oct 3, 2012 | 10:19 AM
oldalaskaman
glad to help
To WTD BB power steering kit advice
