KYB vs monroe shocks
Old Oct 12, 2012 | 01:57 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I looked and I can't find any identification on them for sport of HD, if I were to go from memory I would HD.
Old Oct 12, 2012 | 03:20 PM
MIKE80's Avatar
MIKE80
If I remember right, Bilstein only makes the HD for the rear. HD is not as firm as the Sport, so a combo of Sport front and HD rear for a less stiff ride. But , for all performance do Sports all around.
Old Oct 12, 2012 | 03:50 PM
Tim H's Avatar
Tim H
I refuse to spend over $400 for Blisten shocks!
I have "Gabriel Ultra" for $27 a piece and my vette rides like a Cadillac.
They come from Autozone.
Old Oct 12, 2012 | 04:12 PM
MotorHead's Avatar
MotorHead
Then your missing a nice ride, sure they cost more, anything that is better than something else usually does, a Mercedes costs more than a Ugo
Old Oct 12, 2012 | 06:05 PM
billcarson's Avatar
billcarson
"friends had i gotten the blistin's and a front end alignment i woulda caught em".Name:  SAB33.jpg
Old Oct 12, 2012 | 08:39 PM
Tim H's Avatar
Tim H
33X17X15s cost more than 225/70/15 but they don't ride better.
Old Oct 12, 2012 | 08:48 PM
MakoShark72's Avatar
MakoShark72
The ride was so much better I could not believe a set a shocks could do that and my KYB's were in good condition. I didn't feel every crack and rut in the road, they weren't soft and my Vette stayed stable and flat over going around corners, they are just superior shock absorbers. I can't express how much better they are you have to feel it yourself.
MH,
HD's or Sports?? I have Sports and I think they are a little firm... I have read the HD's are not as stiff??
Old Oct 12, 2012 | 10:21 PM
jb78L-82's Avatar
jb78L-82
I have hd in front with 550 springs and sports in the rear with a 360 composite spring and the car rides great. Sports are 30 % stiffer than the HD's.
Want a cadillac ride, buy a cadillac!! Most mass market shocks are really not very good!
Old Oct 13, 2012 | 12:18 AM
Tim H's Avatar
Tim H
You want Trans Am road course handling buy a Trans Am .
Old Oct 13, 2012 | 12:26 AM
MIKE80's Avatar
MIKE80
My 96' Trans Am I had does not even come close to handling as good as my vette.
Old Oct 13, 2012 | 04:15 AM
Vette5.5's Avatar
Vette5.5
Well, maybe you should. Have a 77' Olds, with custom suspension, and Bilstein HD shocks dated from 1983(still have the receipt). Car's on a 4 post storage lift, so easy to pull things off. Pulled the rear shocks for inspection, with not a drop of oil, and all of the Nitrogen pressure like new. Were $75 bucks each back then.
Old Oct 13, 2012 | 05:40 AM
MotorHead's Avatar
MotorHead
Wow, then I was wrong with that kind of logic. A monster truck tire is probably 10x as much but you would get a smoother ride with a 225/70/15, you outsmarted me again
Or maybe a Michelin Pilot compared to the same size Continental Contipro Contact tire would be better to compare since they are the same size
Old Oct 13, 2012 | 05:51 AM
  #33
MotorHead's Avatar
MotorHead
Originally Posted by MakoShark72
MH,
I am not sure they had the Sports when I bought mine, but I know I wanted a smoother ride as the KYB's were rattling the fillings out of my teeth. I bought them from Van Steel and maybe they steered me to the HD's because they weren't as stiff as the sports.
The difference was just incredible, I would never have thought a set of shocks would make such a difference. Had a big smile on my face after the first test drive.
Old Oct 13, 2012 | 08:11 AM
  #34
jb78L-82's Avatar
jb78L-82
Besides the Bilsteins on my C3 as described above, I also have a complete set of Bilsteins (6 of them BTW) on my 94 Mustang GT convertible and just put 4 Bilsteins on my Chrysler 300. On the mustang, before the Bilsteins I had the oem Ford shocks and the car ride was VERY choppy. I could not believe the smooth ride with the Bilsteins-incredible! Totally transformed the ride and handling. Less than a month ago, I replaced the OEM sachs struts/shocks on the 300 at 80,000 miles and the car rides and handles like a european sports sedan now. Both the Mustang GT and the 300 use the HD version of the shock. The C3 has Sports in the back and HDs in front.
Hope that helps!
Old Oct 13, 2012 | 08:52 AM
  #35
qwank's Avatar
qwank
I just pulled my front suspension apart and I took out some Monroe Sensatrac shocks. They are still in great shape and I think I may reuse them for now but put in Bilstiens later.
These Monroes have oil in them, I don't think I've ever seen a replacement shock that wasn't gas filled.
Old Oct 13, 2012 | 09:42 AM
  #36
Tim H's Avatar
Tim H
Yea, I usually win with logic and well laid out comprehensive plan with a managed inventory thought process.
Old Oct 13, 2012 | 11:42 AM
  #37
TedH's Avatar
TedH
Back in 2005, I replaced all four shocks with KYB (rear) and KYB GR2 (front). Not sure about my reasoning on the mix; perhaps pricing. The Gabriels that were on the car came with it in 1997. I had replaced the front tires shortly before due to severe cupping and felt the shocks deserved some attention. The alignment and condition of the front suspension were fine (all-new components in 1997 and no visible signs of wear or slop). Since then, the car has ridden fine and no more vibrations or cupping of the front tires. After nearly 8 years and fewer than 5,000 miles the tread still looks nearly new.
I would probably install Monroe Sensatrack or Gabriel if I had it to do again. I got way more out of those Gabriels than was intended given I had logged nearly 32k miles and PO probably put another 40K on them.
To KYB vs monroe shocks
Old Oct 13, 2012 | 11:44 AM
  #38
MotorHead's Avatar
MotorHead
Glad you agree, I would like a Ferrari Enzo but no way am I paying a million dollars for one
Old Oct 13, 2012 | 12:20 PM
  #39
Tim H's Avatar
Tim H
Well, just add Blisten shocks and some yellow stickers and you would have it!!!
Old Oct 13, 2012 | 01:23 PM
  #40
mrvette's Avatar
mrvette
Being as Florida is nothing but a sandbar, and the roads full of potholes and patches, the car with KYB and Bilstine actually drives about the same, slightly rougher with the KYB.....
BUT upon recommendations from here some years ago, I upgraded to Bilstein....prime reason is the bridges here tend to have undulations in them so I was being dribbled like a basketball over them at speeds from 60-80+ mph, which is typical speeds here, I have VBP 360 plastic in rear, and 460 coils in front.....
the Bilsteins cured that basketball bounce and I can cruise almost any speed now without feeling like a Harlem Globetrotter......or rather the BALL.......and yes they are better around town too, I have owned this '72 shark vert for almost 18 years now, first 10-12 years with the KYB and since then the Bilsteins.....
OH, forget to mention.....255/50/17 in front 275/50/17 in rear, which are NLA '-(( all mounted on '89 vette rims with wheel adapters.....
