76 vette tac not working
Old Oct 4, 2012 | 09:11 AM
palolaw's Avatar
palolaw
4th Gear
Default 76 vette tac not working
Can some one help with 1976 corvetter tac is not working, how do I repair or should I buy the overhaul kit
Old Oct 4, 2012 | 11:05 AM
1986coupe's Avatar
1986coupe
1st, is it connected properly at the distributor?
2nd, is the connection good between the distributor and the filter?
3rd, are all the connections good to the tach behind the dash?
Check all of that. If there are no problems there then you may have to rebuild the tach.
Old Oct 4, 2012 | 11:12 AM
palolaw's Avatar
palolaw
4th Gear
thank you ill keep you posted
Old Oct 4, 2012 | 11:13 AM
palolaw's Avatar
palolaw
4th Gear
thank keep you posted
Old Oct 4, 2012 | 04:08 PM
bob forty's Avatar
bob forty
mine had a stipped out gear on the distributor side of things.
Old Oct 4, 2012 | 04:49 PM
MrJlr's Avatar
MrJlr
'76 has electronic tach
Old Oct 4, 2012 | 05:02 PM
hunt4cleanair's Avatar
hunt4cleanair
Its estimated 90% of the time its the tach board but as the previous poster indicated, check all the easy stuff first. In your case, if its the tach board, you're looking at tearing the dash out. A couple of forum vendor supporters post information to assist owners...check out Willcox and Zip
Old Oct 4, 2012 | 10:03 PM
Doug1's Avatar
Doug1
the willcox tach board did the trick for my 78
To 76 vette tac not working
