1980 L48 vs. L82
Old Oct 4, 2012 | 09:43 PM
abnormal_vetter's Avatar
abnormal_vetter
Default 1980 L48 vs. L82
Hi guys,
Curiousity has gotten the better of me and have to ask...
What is the difference between a 1980 Corvettes L48 & L82 engines?
I know that there are slight athestic differences between the two, but what is different internally that gives the L82 that extra 40hp? Cam? Pistons?
Old Oct 4, 2012 | 09:52 PM
7t9l82's Avatar
7t9l82
forged crank forged flat top pistons better rods better cam bigger valves .
Old Oct 5, 2012 | 08:46 AM
jb78L-82's Avatar
jb78L-82
There are many differences between the L-82 and the L-48 which is essentially just a GM passenger car engine. The L-82 from 73 to 80 is basically a LT-1 engine with the lower compression pistons like the 1971 LT-1 with 9:1 pistons rated at 330 GROSS HP, not net like all engines were rated in 1972, NOT RHWP on a dyno. The same exact LT-1 rated at 330 Gross HP in 1971 is rated at 255 NET HP in 1972. The 73 to 80 L-82 are essentially the same exact engine internally with the differences mostly exhaust and emissions equipment. So what are the differences between an L-82 and L-48 through all those years?
L-82 VERSUS L-48:
1. Forged pistons/crank versus cast Pistons/ Crank
2. 4 bolt main bearings versus 2 bolt main bearings
3. 9:1 compression pistons versus 8.5:1 pistons
4. Bigger valves on the L-82 versus the smaller valves on the L-48
5. Aluminum GM performance intake versus cast iron standard passenger car intake
5. Bigger exhaust pipe diameter 2.5 in L-82 versus 2.25 in exhaust on L-48 on 75-80 cars.
6. Freeflowing mufflers on L-82 versus L-48 on mid to late 70's cars
7. Higher lift cam on the L-82 versus the standard passenger car cam on L-48
8. Dual snorkel cold air air intake on L-82 versus single snorkel air intake on L-48 in later years.
The HP ratings on the 73-80 L-82's are as follows:All NET HP, NOT Gross HP as prior to 1972.
73-255 HP (True Dual Exhaust)
74-250 HP (True Dual Exhaust)
75-205 HP (first year of cat/Y pipe exhaust)
76-205 HP
77-210 HP
78-220 HP
79-225 HP
80- 230HP
The difference in HP between the years is mostly due to exhaust modifications. Note that a 71 330 Gross HP rating is reduced to 255 NET HP in 1972, a difference of 75 HP just by rating them differently, Gross versus Net!!
The 1980 L-82 was only EPA certified by GM and built with the Turbo 350 Automatic, no 4 speeds.Approximately 5,000 L-82's were sold that year.
Hope that helps!
Old Oct 5, 2012 | 09:54 AM
81pilot's Avatar
81pilot
But, the L-48 had very good torque numbers, the disparity in torque was not there. Just sayin. :O)
Old Oct 5, 2012 | 10:15 AM
jb78L-82's Avatar
jb78L-82
You are correct! The L-48 has better bottom end torque and is often thought to be better suited for the automatic with the L-82 better suited to the 4 speed due to its HP/Torque peaks at mid-high RPM per my comments above.
For example, the 78 L-82 is rated at 220 HP at 5,250 and 260 ft-lbs at 3,600 RPM versus the L-48 ratings of 180 (or 185 can't remember) @ 4,400 RPM and 270/280 ft-lbs @2,400 RPM.
Road and Track confirmed that the 4 speed 78/79 L-82's were faster 0-60 MPH back in the day with the 78 L-82 4 speed (220 HP) doing 6.5 sec and the 79 L-82 Automatic (225 HP) doing 6.6 secs.
I have driven 78-80 L-82's with an automatic versus my 78 4 speed and the difference is startling between the L-82 4 speed and automatic. The automatic "feels" much more sluggish than the 4 speed since the engine revs tend to stay low in the RPM range where the power is not.
To 1980 L48 vs. L82
