Hi
im from italy, i have the 1982 corvette crossfire, when the engine is a lot of warm the engine not starting, this happens especially in the summer.
I change the ignition switch(ecklers 33958) and the starter solenoid, but after some mounth return the problem.
I try to put the direct button to engine starter... The engine starting......some saint can help me?
This is a common problem with Chevrolet vehicles. If you can jump the current across the starter solenoid (battery cable to S terminal - purple wire) and it always starts, then the battery, ground, and starter are good. It could be the solenoid, or the wiring and switches that send current to the solenoid have bad connection or resistance that does not give enough current to engage the solenoid. Here are a couple of threads for this problem. http://forums.corvetteforum.com/c3-t...sometimes.html http://forums.corvetteforum.com/c3-t...k-starter.html
ok 74, thanks.... i will go to check all that u told me, I had also thought of the fuse case, since is very old....and it burning, often fuses. Please can u tell me where i can buy the fuse case??
because for us Europeans to buy this particular parts, is very difficult, in fact, I asked to Painless, and they said do not have the fuse case for my car.
I was not able to open this link... http://www.madelectrical.com/catalog/st-1.shtml
thanks again for ur available
