? Tilt/telescopic swap
It looks pretty straight forward -- rag joint, support bracket inside, electrical. What am I missing?
Also, whats a reasonable price for a tilt column? Contemporary lists them at $425. Are they pretty widely available?
Thanks in advance...
--Jack
Just make sure that the column comes with all the necessary horn button, telescoping lever, extension, hub, turn signal and tilt levers, etc. Your original steering wheel itself should bolt right on to the hub.
A 1976 column will also bolt-in but the steering wheel as well as the horn button, hub, extension, and telescoping lever are all unique to that one year. So unless you like the 1976 style wheel and you get everything with it, stay clear of this one year only design.
A little more detail can be found at http://www.corvettefaq.com under Steering. Look for a paper on Steering Wheel and Horn Parts.
Paragon Reproductions Inc
(800) 882-4688
CorVette Steering Service Inc
(864) 287-9990
Steering Columns Galore Inc
(888) 326-5866
Are three other possible sources of complete T&T columns.
[Modified by Jim Shea, 8:59 AM 6/4/2002]
If I can be of further assistance either post on the corvetteforum or eMail me.
