CAR PULLS TO THE LEFT WHEN BRAKING
Old Jun 4, 2002 | 09:44 AM
mdm1's Avatar
mdm1
Default CAR PULLS TO THE LEFT WHEN BRAKING
I just replaced the front calibers on my 1975 Corvette with stainless steel units (the rears have already been replaced). The car now and then pulls to the left when braking. This is confusing me because it doesn't do it all the time. If I let the car sit overnight and take it for a ride, it brakes straight but after 10 minutes of braking it starts to pull. Could it be the proportioning value or maybe a collapsed brake hose? Any thoughts on this matter would be greatly appreciated, you may e-mail me at: MDM1@WESTCHESTERGOV.COM
Old Jun 4, 2002 | 09:52 AM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Default Re: CAR PULLS TO THE LEFT WHEN BRAKING (mdm1)
I would start with replacing the brake hoses. Make sure your getting a nice strong flow when bleeding the calipers. Good luck :cheers: .
Old Jun 4, 2002 | 09:59 AM
Maco Shark's Avatar
Maco Shark
I agree. If your car pulls left, then probably the right rubber hose is collapsed inside. I have had this problem several times over the years with many vehicles. Replace both hoses, as if one is bad, then the other cant be far behind. If you get them air free, then you should have good brakes.
Good luck, :cheers:
Old Jun 4, 2002 | 10:02 AM
ylose's Avatar
ylose
Default Re: CAR PULLS TO THE LEFT WHEN BRAKING (Maco Shark)
haven't seen that sig in a while Maco, love it.
I agree with their opinions.... :yesnod:
Old Jun 4, 2002 | 10:09 AM
norvalwilhelm's Avatar
norvalwilhelm
Also look at the inside of the tire and see if there are streaks on it. It would mean one of the new calipers are leaking. Just because they are new doesn't mean they won't leak. Some new calipers take a while before they stop leaking. I know this doesn't make sense but I had a brand new leaker and drove on it for a few weeks, too lazy to remove it and send it back. Finally phoned the company and they said send it back. Another week went buy and it stop leaking. Had it on for a year now and no tell tale strecks on the tire and a dry rim. This leaking will cause pulling
Old Jun 4, 2002 | 12:39 PM
thejaf's Avatar
thejaf
Default Re: CAR PULLS TO THE LEFT WHEN BRAKING (norvalwilhelm)
You need to remove "national public radio" from your presets. :smash:
Old Jun 4, 2002 | 12:41 PM
Fevre's Avatar
Fevre
Default Re: CAR PULLS TO THE LEFT WHEN BRAKING (thejaf)
NPR: Not Particularly Relevent
Old Jun 4, 2002 | 05:19 PM
Ryan77's Avatar
Ryan77
Default Re: CAR PULLS TO THE LEFT WHEN BRAKING (Fevre)
It is also possible that you twisted the hard line when installing the hoses. Check both the hoses and the lines.
Old Jun 4, 2002 | 06:13 PM
lou's Avatar
lou
Also check the brake pads and rotors. Make sure they don't have any brake fluid on them and are clean. Also if you installed the original brake pads back on and swapped the inboard pad and outboard pad, it could take a few days of driving to break them back in with the rotor and get equal braking. lou
Old Jun 4, 2002 | 08:00 PM
BlkBird's Avatar
BlkBird
Default Re: CAR PULLS TO THE LEFT WHEN BRAKING (lou)
Im going with the brake hose(on the opposite side the car pulls to) as well, this happened on my wifes Z and had me going crazy 'til I found it...then I just felt stupid :bb
To CAR PULLS TO THE LEFT WHEN BRAKING
