My blinkers stopped working!
Old Jun 4, 2002 | 10:22 AM
68ragtop's Avatar
68ragtop
Default My blinkers stopped working!
I checked the obvious, the fuse is good. I get absolutely nothing, any idea's? I need to meter at the fuse block to see if the power is getting there.
Old Jun 4, 2002 | 10:41 AM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
Default Re: My blinkers stopped working! (68ragtop)
Do the emergency flashers still work? If so, check the blinker unit and its connection under passenger side.
Old Jun 4, 2002 | 10:47 AM
68ragtop's Avatar
68ragtop
Default Re: My blinkers stopped working! (BlueL36)
Nope, they haven't worked since I've owned the car.
Old Jun 4, 2002 | 04:18 PM
JIM's Avatar
JIM
probably the switch in the column. I think I got mine from corvette central.
Old Jun 4, 2002 | 08:19 PM
BlkBird's Avatar
BlkBird
Default Re: My blinkers stopped working! (JIM)
Need more info. Do they light up, but just dont flash or do they not light up at all? My wifes Z just had a wierd problem where the left side would flash, but the right side would just light up but not flash, and with the hazards on they would all flash. It ended up being the flasher. $4. I though if the flasher went out, it would'nt work at all, I was wrong. Id spend the 4$ for a flasher before I buy the new switch.
Old Jun 4, 2002 | 09:04 PM
GaryS's Avatar
GaryS
You said you checked the obvious, but did you check the flasher unit that is held to a clip under the passenger side of the dash (at least that is where it is on my 72)? This is the 1 1/2" diameter flasher unit (mine is blue plastic) that is about the same height. I think it controls all of the turn signal and emerg. flashers.
Gary
Old Jun 4, 2002 | 09:19 PM
dogboy's Avatar
dogboy
Default Re: My blinkers stopped working! (GaryS)
Does power go to the lights? If fuse is okay its probably the flasher under the pass. side dash. I had the same thing a few months ago & that was the culprit. Cost - $2.00
Old Jun 4, 2002 | 10:34 PM
68ragtop's Avatar
68ragtop
Default Re: My blinkers stopped working! (dogboy)
This site is Great. It was the flasher unit under the passenger side dash like some of you guys suggested, Thanks!
To My blinkers stopped working!
