Shift light taco - LS3?
Old Oct 8, 2012 | 03:41 PM
corvettedave383's Avatar
corvettedave383
Default Shift light taco - LS3?
again ls3 install, can anyone point me in the direction of a shift light rev counters that will work with the gm ls3, there is a tacho wire in the bulkhead connector in the gm wiring loom
cheers
dave
Old Oct 8, 2012 | 03:47 PM
Garys 68's Avatar
Garys 68
The original programming puts out a 4 cylinder tach signal (fires on compression and exhaust stroke). I'm using a tach set to 4 cylinder.
You can reprogram for an 8 cylinder output too and use a standard V8 tach. Check over at LS1tech conversions or tuning boards for instructions, or just have a tuner do it.
Old Oct 8, 2012 | 04:24 PM
MrJlr's Avatar
MrJlr
Never mind...I thought this was about tacos.....
To Shift light taco - LS3?
