My distributor won't drop in.
Old Oct 11, 2012 | 06:39 PM
540 vette's Avatar
540 vette
Default My distributor won't drop in.
I am getting ready to start up my new 355 . I primed it today and got plenty of oil pressure oil came right up to the rockers. The motor has a Performer RPM hydraulic roller cam in it. I am using an Accel hei distributor I had in the 350 that was in the car and it fit fine.
I went to put the distributor in and it goes in but sticks up about 1 inch and will not go in. It seems to engage the cam gear because it won't spin but will not go in. And yes I checked the oil pump rod and spun it so it would go in the groove.
The priming tool I use is an old distributor and that goes right in. I also put some grease on the end of the dist gear to see if it hit the oil pump shaft and it didn't.
Another question, the oil shaft moves around in the hole where it comes up from the pump, is that normal.
Old Oct 11, 2012 | 07:58 PM
gve's Avatar
gve
The shaft from the pump will have a little play I would check the dist. gear to make sure there are not any nicks or damage.
Old Oct 11, 2012 | 08:37 PM
68thumper's Avatar
68thumper
Not sure I understand what you are saying here. If the gear on the dizzy engages the cam then you should be able to wiggle it until the oil shaft engages or the gear on the dizzy hits the shaft.
This is normal when the dizzy is not engaged. Now I'm "dizzy"...
Old Oct 11, 2012 | 08:50 PM
540 vette's Avatar
540 vette
Distributor has 2 miles on it. No chips or anything. The shaft is leaning to one side and isn't centered so the shaft dosen't go into the gear. It dosen't matter if it's lined up the dist won't slide over the shaft.
Old Oct 11, 2012 | 08:55 PM
centralcalvette's Avatar
centralcalvette
The oil pump drive shaft isn't engaging. Turn it with a large screwdriver, it should be about 15 degrees off the distributor tang.
Old Oct 11, 2012 | 08:57 PM
68thumper's Avatar
68thumper
The shaft will always lean to one side before the distributor is dropped in. Assuming the motor is at TDC and the rotor on the distributor facing towards the number 5 cylinder (Chevy) "approximately" you should be able to put light pressure on the distributor and have someone bump then engine over to align the slot in the distributor gear and the oil pump shaft.
Old Oct 11, 2012 | 09:02 PM
TimAT's Avatar
TimAT
The bottom of the distributor gear is tapered so it will lead the oil pump shaft into it. If the pump shaft is too far off to the side, there may be a problem with the collar on the shaft at the pump. THe lower shaft will be a little off center, but not laying on one side or the other- it should be pretty well centered in the hole.
Old Oct 11, 2012 | 11:32 PM
PhotoVette1's Avatar
PhotoVette1
The old school trick is to put a brick on top of the distributor and nudge the starter. It worked for me.
Old Oct 12, 2012 | 01:08 AM
AF_Vette's Avatar
AF_Vette
I agree except for the brick. bump and engine over and the distributor will drop in.
Old Oct 12, 2012 | 01:09 AM
Peterbuilt's Avatar
Peterbuilt
Any chance the gear on the end of the distributor is upside down?
Old Oct 12, 2012 | 06:27 AM
Danish Shark's Avatar
Danish Shark
Bingo
Old Oct 12, 2012 | 06:37 AM
cv67's Avatar
cv67
St. Jude Donor '05
Keep bumping it over with slight pressure downward it will drop in
Old Oct 13, 2012 | 06:28 PM
drwet's Avatar
drwet
I've had the same problem a couple of times. It usually turns out I haven't had the slot in the end of the pump drive shaft lined up correctly. With enough fooling around I eventually get it. If the engine is in the car and the starter bolted up bumping it over works too. I don't like to do this because I then have to set the engine up to top dead center again to static time it, but it works.
Old Oct 14, 2012 | 09:14 AM
STL 71 C3's Avatar
STL 71 C3
this is impossible ^^
What intake do you have?
I would look at alignment of intake....if you have a PP or one made in China, that's your problem
Old Oct 14, 2012 | 10:02 AM
540 vette's Avatar
540 vette
I got the distributor in. The shaft was sloppy in the hole and was not centered and yes I used a steel bushing. I jacked up one side of the car and that centered the shaft and the distributor went in with a little jiggle.
Old Oct 14, 2012 | 02:51 PM
C3 4ME's Avatar
C3 4ME
I've had good luck just bumping the engine till it drops in. No brick or downward force needed.
Old Oct 14, 2012 | 04:54 PM
540 vette's Avatar
540 vette
I couyld have bumped it for a year and it would not have gone in because the shaft wasn't in the bottom of the dist. The keyway was in the right spot but the shaft was off to one side.
Old Oct 14, 2012 | 05:17 PM
billla's Avatar
billla
St. Jude Donor '14
The intermediate shaft isn't a precision fit by any means, but I've never had one I couldn't drop by bumping it - hard to imagine the hole could be THAT out of round.
But the important thing is that it's in
To My distributor won't drop in.
