St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Tilt Column For My 70
Another one of those projects I would like to do to my 70 is add a tilt steering column to it. I don't want to add a truck column or something like that. I would like for it to be another vette column. If I remember correctly some columns are more of a direct fit for some reason for earlier cars versus later C3. If anyone knows what years would fit mine easiest please feel free to chime in.
76's will work to, but you need the hub adapter kit, that eliminates the infamous "Vega" steering wheel.
78-82's can be used, with a little work. They're a little different length, and have the high beam control on the column, instead of the floor. They're also a lot cheaper than the early columns.
Forget the 77 column. It's a one year only column, with both the wiper and high beam control, on the column.
Originally Posted by gbvette62
69-75 are there direct bolt in.
What hub adapter are you referring to use the 76 column? Is this a part that can be removed from my stock 70 column? Is this 76 column a bolt in as far as electrical connections?
