* Alternator Wiring Help *
Old Oct 13, 2012 | 11:23 AM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Default * Alternator Wiring Help *
I recently installed a 100amp alternator and would like to see pics of how to install a heavier gauge wire to support the extra current.
Which gauge wire do I use?
Do I have to install an inline fuse somewhere along the line?
What size fuse?
Any help is appreciated even if you don't have pics.
Thanks, Les
http://www.summitracing.com/parts/PWM-27294/
Old Oct 13, 2012 | 12:14 PM
LongIsland C3's Avatar
LongIsland C3
Is it a replacement style alternator? Or did you purchase the single wire setup?
Old Oct 13, 2012 | 01:13 PM
oldalaskaman's Avatar
oldalaskaman
I ran an 8 gauge wire from the positive post on the back of the alternator to the large positive post on the starter. I didnt remove the original wire but left it in parallel with it. works fine. most of the rebuilders sell them already made up in any length you need. used a 120 amp fuse. hope this helps
http://www.google.com/url?sa=t&rct=j...tM1ZOOWlDOmFKw
Old Oct 13, 2012 | 05:55 PM
AGVI's Avatar
AGVI
Replacement style which can be used as a one wire setup.
Old Oct 13, 2012 | 06:00 PM
flaco1801's Avatar
flaco1801
Alaska...in real world an 8 gauge wire is fused for 45 amps...car world is different?.. just askin..
Old Oct 13, 2012 | 06:10 PM
AGVI's Avatar
AGVI
OK, Cool. What size alternator did you use? I guess I need to use an 80 amp fuse since my alt is 100 amp and the link you provided states to use a fuse at 80% of the alt's output?
Les
Old Oct 13, 2012 | 07:28 PM
oldalaskaman
no , its the same, but I fused it to the output of my alternator, if the alternator starts juicing higher amps then that , I'd like the fuse to pop before it damages things
Old Oct 13, 2012 | 07:32 PM
bluthundr's Avatar
bluthundr
It's fused so that the current draw doesn't exceed the capabilities of the wire. It doesn't matter how many amps the alternator can provide.
Old Oct 13, 2012 | 07:34 PM
oldalaskaman
Les
My alt. is one of the skip white 120 amp versions. I'm also running two big electric radiator fans, a mini frankinstarter, High amp driving lights. If something spikes, say a relay fries, it gives it a bit of time to unspike itself. You are best staying with the 80% thinking,its safe and wont hurt the performance
Old Oct 13, 2012 | 07:36 PM
oldalaskaman
a lot depends on how you hook it up , accessories, series or parallel, etc. but you are right . I have mine set up a bit different
Old Oct 13, 2012 | 07:37 PM
oldalaskaman
What size fuse?
Thanks, Les
power master has some excellent tech on their site
btw you will be happier with it as a three wire, there is a lot of tech. on the difference from a one wire
Old Oct 13, 2012 | 08:07 PM
oldalaskaman
Heres some tech from powermaster
http://www.powermastermotorsports.com/charge_wires.html
the absolute best advice I can give it to follow powermasters recommended way of doing it
1. they built the alternator and know what works
2. if you dont do it their way it may void your warranty
3. their warranty is only good for 12 months from the date of purchase
hope this helps
http://www.powermastermotorsports.co...ternators.html
Old Oct 14, 2012 | 06:12 PM
AGVI's Avatar
AGVI
Yeah, I'm just gonna throw an 8 awg wire in between the alt and the starter with a fuse in between and wait for the fire.
Old Oct 14, 2012 | 06:21 PM
oldalaskaman
Old Oct 14, 2012 | 07:05 PM
flaco1801's Avatar
flaco1801
the wire will become the fusible link if the fuse is rated higher than the wire....
Old Oct 14, 2012 | 07:22 PM
oldalaskaman
you're right again , and thats what both those sites recommended. 80% of alt output
Old Oct 14, 2012 | 08:00 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I ran a parallel wire with my existing wiring too, great minds think alike, shares the load
To * Alternator Wiring Help *
