Thinking of going big
Old Oct 15, 2012 | 10:23 PM
BBCorv70's Avatar
BBCorv70
Originally Posted by John 65
Heres my set up. Has a drop base air cleaner on a Performer RPM manifold with a big fat Holley carb sitting on it and no need for any hood mods, it all fits under my stock 77 hood, which is a HUGE savings. Plus it looks 100% stock with the hood closed.
I like the placement of the alternator, doesn't sit on top of the power steering pump as the stock setup does. Difficult to check the power steering fluid. If you have no AC, this setup works well.
Old Oct 15, 2012 | 10:54 PM
John 65's Avatar
John 65
Thanks, Its a simple set-up and works well. Hope it helps the OP some if he is not going for the correct vette set-up.
