Compression Test.......
Old Oct 15, 2012 | 05:30 PM
billla's Avatar
billla
St. Jude Donor '14
I've seen both sides of the coin and it's based a lot more on how the engine is maintained than anything else. Certainly synthetic oils have changed things dramatically as well.
I tore down a 300K+ 350 from a '70 C-10, never touched, and honestly...I could have just put it back together. Everything was within service limits. The truck had been very well-maintained, although worked hard.
OTOH, I tore down a relatively new (80K, I think?) Vortec pull-out over the weekend...it was full of garbage and the wear showed it.
The bottom line is that we overhaul based on condition, not just age or miles. If the oil pressure is good and the leak-down is acceptable...then just run it. :cheers
Old Oct 15, 2012 | 06:28 PM
694speed350's Avatar
694speed350
Originally Posted by robieWI
Soooo...I did a compression test today and here are the results. I think I know where this is going, but I wanted some other thoughts/interpretations of the results. Plugs were all over the map too...oil, carbon deposits and some high speed glazing, sometimes on the same plug
At least my 9 y/o daughter got a lesson in engine compression....she was my key turner
Any help is appreciated
Oh yeah...engine is L48 with an alleged 120K on the clock
1- 65 Did not go up after injecting oil
2- 130
3- 130
4- 135
5- 125 Dropped off quickly
6- 125
7- 120 Dropped off quickly
8- 125
tear it down do a compleye rebuild and forget about it. seems low even with a low compression engine.
Old Oct 15, 2012 | 07:13 PM
billla's Avatar
billla
St. Jude Donor '14
Around 160+ is what we'd be looking for in an old GEN I - but these numbers aren't horrible and they're consistent across the cylinders- except for #1.
Old Oct 15, 2012 | 07:53 PM
540 RAT's Avatar
540 RAT
I have read a little on performing the leak down test, but have never done one. Is there anything special I need instrumentation wise?
As others have said, she's old and tired, and needs a rebuild. But, if you do want to diagnose the particulars, using a compression tester to check the basic condition of an engine is better than nothing, but it is NOT the best choice. Compression test results can be inaccurate and inconsistent. This is because the condition of the battery, variations in ambient temperature, and the effects of the presence or lack of oil (if the engine has been sitting) around the rings which helps seal them, can all affect the results. This makes a compression test only a mediocre test at best.
Leakdown testing is by far the BEST METHOD for checking an engine’s basic condition. It is done by checking each cylinder at TDC of the compression stroke. And any leakage heard, helps to pinpoint where any problems are located. Air leaking out of the carb indicates a leaking intake valve. Air leaking out of the exhaust system indicates a leaking exhaust valve. Air leaking out of a breather indicates ring leakage. And air leaking out of the radiator cap opening indicates a leaking head gasket.
I’ve tested the 3 different types of leakdown testers.
One is a single gauge tester that reads leakdown percentage directly. This one is NOT recommended because its accuracy is typically not very good.
Another one is a dual gauge “low input pressure (typically around 35 psi or less, depending on the particular unit)” type that has one psi gauge and one gauge face that shows leakdown percentage directly. These are usually fairly inexpensive (this is the kind you typically find at Harbor Freight), and are also NOT recommended because of their typical inaccuracy. I've seen them be off by 5% or more, which might be good enough for those who just want to see what is going on in general. But, this type won't provide the true leakage %.
And the last type is a matching dual psi gauge “high input pressure (usually can go up to 100 psi)” type. This type is not that hard to use, and provides excellent accuracy, making it clearly the best of the 3 leakdown tester types. So, if you decide to get a leakdown tester, do yourself a favor and get this type.
Note: Input pressure can be referred to in two ways, static and dynamic. Static means you set the regulator to the desired input pressure, say 80 psi (more on that below) with the tester NOT connected to the engine yet.
Then once you do connect the tester to the engine, the pressure will drop somewhat, becoming dynamic input pressure. You can then readjust the regulator to bring that dynamic input pressure back up to the original 80 psi, if you want. But I’ve found no difference at all in the final leakdown percentage results between doing that, or just letting the pressure drop somewhat and leaving it there. So, the most convenient method is to simply set the static input pressure to 80 psi and simply leave it.
The way to get to the final answer for a given test is:
For example, after you connect the 80 psi static pressurized tester to the engine, the left side regulator controlled gauge may say something like 70 psi after it drops, while the right side engine leakage gauge may say something like 65 psi.
You just plug a few numbers into your calculator, in the following manner:
You ask yourself, 65 psi on the leakage gauge is what % of the 70 psi on the dynamic input pressure gauge? And you punch into the calculator 65/.70 (don’t forget that its “point” 70 here) and the answer comes up 92.8, which means that the right side leakage gauge is showing or holding 92.8% as much as the left side input gauge. And because the original 70 psi dynamic input pressure was 100% of the dynamic input pressure, you simply punch into your calculator 100 – 92.8 = 7.2% leakage in that cylinder, which is your final accurate answer for that cylinder. That’s all there is to it.
For those who don’t use much math, that may seem like too much trouble. But if you read through what was done a couple of times, and then actually do it a couple of times, you’ll see that it’s no big deal at all. And you’ll be crunching the numbers freely after the first couple of cylinders.
There is no universally accepted input pressure for automotive leakdown testing. But the FAA (Federal Aviation Administration) has established 80 psi input pressure as their standard for leakdown testing on piston aircraft engines. And they allow up to 25% leakdown in those aircraft engines.
That 80 psi input pressure works perfectly fine for car engines too, so I use that as my input pressure as well.
And the reference chart I use for COLD leakdown testing on High Performance Engines is:
0-10% = good condition
10-15% = though not ideal, still acceptable
over 15% = tear down and repair recommended for optimum performance
(for non-performance daily driver/grocery getter type vehicles, over 30% = tear down and repair recommended)
As a point of reference, my 540ci BBC Street/Strip engine shows a COLD leakdown of about 3%, using conventional Speed Pro rings, with a top ring end gap of .021” and a second ring end gap of .027”. And keep in mind that anytime you do a leakdown test, at least with conventional rings, you will hear some air leakage. Even for the small amount of leakdown that my engine shows, I can still hear some air leakage hissing out of the breathers, from the ring end gaps.
Here’s the excellent leakdown tester that I use and like real well. It’s from “Goodson Tools and Supplies for Engine Builders”
http://www.goodson.com/Dual-Gauge_Leak-Down_Tester/
540 RAT
Member SAE (Society of Automotive Engineers)
Old Oct 15, 2012 | 10:45 PM
robieWI's Avatar
robieWI
From: Horizontally parked in a parallel universe. WI
Very good discussion here.
I would agree that testing and troubleshooting are always the way to go. After 15+ years in a technical trade(Commercial HVAC/R), I've seen a lot of parts changers out there. It always frustrates me when I walk on a job and hear that the guy or guys' before me changed all these parts and it still does not work
" It's not good enough to know what part needs to be changed, you have to know WHY it needs to be changed."
540RAT- Very nice piece on the leak down test. I do like a lot of Goodson's tools and equip. Been looking at some of their measuring instruments.
All of that being said, I will perform a leakdown test. I have a friend who has a tester very close to the Goodson one that 540RAT mentioned and he will assist me with the test. IF anything to learn and answer that question of WHY.
I will post the results, may not be real soon, but I will get them to you guys.
In the end I will end up pulling this engine and starting on the design/build of a new powertrain for this car. I have owned it for 3 years now and had some fun with her and got to "know" her pretty well.
I have been considering going off the deep end and pulling the body. But there are some nagging questions/concerns I have and until I resolve those, with some research and knowledge, I am not ready to make that decision yet.
Lots to consider, lots to plan, and a whole lot to do. That's why it's a hobby and not a job. And I do it for the enjoyment not the money. Like watching my nine year old turn the key to Dads Vette with a big ole sh*t eating grin on her face, and then asking about what we were doing
Old Oct 16, 2012 | 12:37 AM
billla's Avatar
billla
St. Jude Donor '14
Unless the engine is a modern, recent and high-performance build, ~20% leakdown isn't a big deal...depending to some extent where the loss is.
