69 Interior Mirror
Has anyone out there ever removed/replaced the mirror glass in a 69 Vet?
I would like to remove mine so I can either refurbish or replace the glass,
as the chrome is starting to lift off the glass and I'd rather leave it alone than break it.
Thanks for any held provided.
Mark
If you just want to swap the glass...you're going to likely have to break it and take out all the pieces. Stick the new glass in there with some adhesive and run the rubber retainer thing around the edges and away you go.
I wanted to replace the glass in my 1976, and would have just bought a new assembly, but it came from the factory wth a map light and I wanted to keep that...so am going the smashy smashy route.
23772 1967-1973 Inside Mirror Glass. 67-73
But.. on the other hand, you can buy the entire mirror for less than the glass.
Inside Mirror. Correct 67-71
it into a glass shop and see if they can cut me a new piece to suit.
Flaco1801, we have a standup comedian here in Australia called Flacco, he's quite good,
look him up on youtube, there are quite a few videos of his acts.
Willcox thanks for the links, but I'll try and replace the glass here before buying a new mirror.
Mark
