Inline pump
Old Oct 17, 2012 | 07:55 AM
bytor's Avatar
bytor
Default Inline pump
Considering going with an EFI setup for a 383 build I’m working on and have a fuel delivery question. Has anyone had success running an inline fuel pump (Walbro GLS392) with a late model top feed tank? I have a 78 and I'm seeing mixed reviews of gravity feed pumps with the top feed tanks. How big of an issue is this for a street car?
Old Oct 17, 2012 | 09:21 AM
oldalaskaman's Avatar
oldalaskaman
Its been done a few times with success over in c4, that may be a good place to post your question, C4's are top feed also. hope this helps
Old Oct 17, 2012 | 09:56 AM
74modified's Avatar
74modified
Many people use them. You can get it to work, its just more likely to have problems. Electric pumps push better than pull. The fuel also cools the pump, so starvation is more than just an engine operation problem, pump life comes into play. You didnt ask, but I like in the tank (factory style) - they usually have a reason behind their designs.http://forums.corvetteforum.com/c3-t...fuel-cell.html
Old Oct 17, 2012 | 10:07 AM
oldalaskaman
http://www.google.com/url?sa=t&rct=j...rZAVOVfU2Okc2A
fords have been using inline frame mounted injection pumps for years as have several others, from top feed tanks, they work. you could actually use a ford inline pump on a chevy with a bit of line adapting, I've done that. hope this helps
btw, a stock inline ford pump, bout $60, fancy inline pump,bout $250
same pressure, same volume, last for years, they will suck your tank dry
Old Oct 19, 2012 | 11:31 AM
bytor's Avatar
bytor
Thanks for the feedback.
So will an 82 fuel pickup like this. http://www.ecklerscorvette.com/corve...pump-1982.html
drop right into my tank without any modifications? What's the right in tank pump to use with this setup? This seems like an easer route than having to cut the stock fuel line.
What are a few part numbers for the Ford inline electrics fuel pump?
Old Oct 19, 2012 | 12:01 PM
74modified's Avatar
74modified
I am not an expert on tank differances, but the gasket for 78-82 is the samehttp://www.ecklerscorvette.com/corve...1978-1982.html This would lead me to think you could use the later sending unit/pump. The pump you need would depend on the pressure required by the injection system you plan to use.
Old Oct 19, 2012 | 12:10 PM
bytor's Avatar
bytor
45psi. 220lph
Old Oct 19, 2012 | 12:28 PM
SuperBuickGuy's Avatar
SuperBuickGuy
seriously, call walpro, or whoever is making your fuel injection system for specs.
In a C3, I don't see a problem in the world with a frame mount since the pump is well below the tank. They put the pump in the tank for several reasons including: it's easier to keep cool (longevity), and costs less to manufacture because you simply drop the pump in the tank and it goes in as unit.
But as Alaska points out, frame mount fuel pumps have been around for decades without problem. The biggest issue with a pump is if they starve for fuel for an extended time - they'll overheat and eventually die.
To Inline pump
