Need Some Torque Specs
Old Oct 18, 2012 | 08:43 PM
76Vett's Avatar
76Vett
Default Need Some Torque Specs
I have a AIM for my 76 Vett but either it's missing or just doesn't have it, but I need the torque specs for the u-joint flange bolts, Cross member to differential bolts, Spring mount plate to differential bolts, and just to confirm , are the U-joint straps and U-bolts torqued to the same spec? Your help is appreciated - Thanks.
Old Oct 18, 2012 | 09:16 PM
76Vett's Avatar
76Vett
Thanks - thats everything I needed. Printed and put a hard copy in my Manual.
