Offset TA incompatibility....
Old Jun 5, 2002 | 12:14 PM
Jenny's Avatar
Jenny
Default Offset TA incompatibility....
We finished up the rear end last night, and got to the point of mounting the caliper onto the Trailing Arm. Well it wouldn't fit. The bottom edge where the bolt goes into the mounting bracket was hitting the T/A. We had to grind some of the metal off of the caliper and reinstall. The car drives really well, it's so much fun... i'll make a separate thread with some pictures. Just wanted to let you guys know :seeya
Old Jun 5, 2002 | 12:40 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Default Re: Offset TA incompatibility.... (Jenny)
Is it typical to clearance the calipers to fit the offsets? This is the first time I've heard of that. I've been thinking of saving up for a set of offsets for my car.
Glad to hear it's all back together and working well for you :cool: .
Old Jun 5, 2002 | 12:48 PM
Chris Fowler's Avatar
Chris Fowler
Cruise-In IV Veteran
St. Jude Donor '03-'10
Are you using a stock caliper? I remember you bought new ones a while back...
Old Jun 5, 2002 | 12:53 PM
Jenny's Avatar
Jenny
Default Re: Offset TA incompatibility.... (Chris Fowler '80)
You are correct.. they are from stainlesssteelbrakes.com They fit on the stock trailing arm with no problems. I can take a look at my old cores that I still have here.. but i believe those are rounded on the bottom aswell?
Old Jun 5, 2002 | 05:10 PM
fauxrs's Avatar
fauxrs
Default Re: Offset TA incompatibility.... (SmokedTires)
My rebuilt original calipers on the rear mounted with no worries.
Old Jun 6, 2002 | 02:23 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
WOW glad to hear it's back on the road :cheers:
Old Jun 6, 2002 | 02:27 AM
Armstrong's Avatar
Armstrong
Great Job!!! You guys have done alot in a short time. Now it's time to enjoy. Great team work.
Old Jun 6, 2002 | 10:54 AM
74-Roadster's Avatar
74-Roadster
St. Jude Donor '06
Father & Son St. Jude Donor '09
Since you're going with offset arms, what size of wheels and tires are you installing?
Thanks for the tip as well. Is the little bit of grinding visable?
Old Jun 6, 2002 | 01:21 PM
Captain Morgan's Avatar
Captain Morgan
Cruise-In V Veteran
Congrats Jen!! Glad you've got it out on the road again. :cheers:
Old Jun 6, 2002 | 03:24 PM
mrvette's Avatar
mrvette
Jenny, would like to know how much clearnace there is behind the stock wheel/tire as it passes over the T-arm area....
Also, what you thought of that company....
GENE
Old Jun 6, 2002 | 04:19 PM
Darkness's Avatar
Darkness
Default Re: Offset TA incompatibility.... (mrvette)
C3's do ride exiting dont they? :cool:
Old Jun 7, 2002 | 12:07 AM
Tom454's Avatar
Tom454
Default Re: Offset TA incompatibility.... (inferno-vette)
I did the grinding on the calipers....
I believe this is not a typical requirement, because I also have offset T/A's on my 70 and there were no clearance problems with my calipers.
I didn't investigate the source of the calipers Jenny has... it was 2:00 am and I was pretty dirty & greasy by then.... just wanted to get the car rolling.
I had to grind off part of the caliper rearward mounting tab, just below the bolt hole. The casting was hitting the T/A and preventing the caliper mounting bolt from starting in the threads in the caliper support.
I was surprised there was a problem... haven't seen this one before.
I used a heavy duty body grinder with about a 36 grit disc. I had to grind off a fair amount. Because the tab is so close to the T/A, it is pretty difficult to see the modification unless you are looking for it.
PS- While I was packing up my tools, I heard Jenny frying the tires off in the distance. Sheesh. She just couldn't wait until morning.
Old Jun 7, 2002 | 01:57 AM
Captain Morgan
Cruise-In V Veteran
Default Re: Offset TA incompatibility.... (Tom454)
:D Good for her. I wouldn't have been able to wait either. :D
Old Jun 7, 2002 | 03:01 AM
Merlin522's Avatar
Merlin522
Default Re: Offset TA incompatibility.... (Captain Morgan)
Go Jen!! :D
Old Jun 7, 2002 | 04:19 AM
C3 Shark Tank's Avatar
C3 Shark Tank
Call me silly but I fail to see what's wrong with that, I did the same thing after 4 months of being in the garage :jester
Old Jun 7, 2002 | 12:02 PM
Tom454's Avatar
Tom454
Default Re: Offset TA incompatibility.... (C3 Shark Tank)
I didn't see anything wrong with it either.... it put a great big smile on my face when I heard it. :)
To Offset TA incompatibility....
