RPM readings
Old Oct 21, 2012 | 10:33 AM
Iron_dog's Avatar
Iron_dog
Default RPM readings
Hi guys,
while checking for idle RPM I've found that the gauge reading is different from timing light reading... which is about 400 RPM lower... what's wrong??
Old Oct 21, 2012 | 12:15 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
What gauge is "reading different"?
My timing light does not show rpm. I use my dwell/tach for that.
At idle, what rpm shows on your tachometer?
Old Oct 22, 2012 | 03:23 AM
Iron_dog's Avatar
Iron_dog
I've a timing light with dwell/tach functions. At idle instr gauge is 1000 while timing light shows 600... I dont know which is the right one...
This is my timing light:
http://www.lawson-his.co.uk/assets/d...ns/TL93_V2.pdf
thanks!
Old Oct 22, 2012 | 03:29 AM
marshal135's Avatar
marshal135
Veteran: Marine Corps
My mechanical tach remains un rebuilt on my 68 BB.
My timing light and dwell meter both show 710 RPMS.
My tach guage shows 700.I'm not worried about that small margin.
400 RPMS seems like allot to be off.
Not trying to be smart but was the light defaulted to 4 cycle?
Marshal
Old Oct 22, 2012 | 04:44 AM
Iron_dog's Avatar
Iron_dog
Marshal
Marshal... I think you are right! I've realized the unit has two different modes: 2 strokes and 4 strokes! I think I set it wrong... thank you!
Old Oct 22, 2012 | 05:00 AM
marshal135's Avatar
marshal135
You are most welcome.
This forum has been such a wealth of help to me as well.Now its time for me to pay it forward.
Don't forget to disconnect the distributor vac advance if you are timing.'Its easy to forget.
Marshal
To RPM readings
