Fuel Pump Pushrod - Couple questions
Old Oct 25, 2012 | 03:37 PM
gbarmore's Avatar
gbarmore
Default Fuel Pump Pushrod - Couple questions
Just got a new 383 stroker and was planning on reusing the fuel pump and pushrod from my old L48. I got to thinking about it and wonder if I should be replacing the pushrod because I now have a roller? The old pushrod shows no sign of wear whatsoever (~45K on the L48).
Also, it seems that there are a couple different length pushrods available for a SBC, a 5.75" which is what I have, and a 5.95". Does the longer pushrod simply develop more pressure, or is it for a different application??
Oh yeah, I'm assuming my L48 fuel pump will be sufficient to feed my 383, but any thoughts on that would be appreciated as well.
Thanks!
Old Oct 25, 2012 | 05:54 PM
DRIVESHAFT's Avatar
DRIVESHAFT
If you have a billet roller cam, you should run a bronze tipped pushrod.
If you've got one of the cast roller cams then you should be able to run a normal pushrod.
Old Oct 25, 2012 | 08:12 PM
gbarmore's Avatar
gbarmore
It's a billet roller, looks like I'll add it to the ever expanding shopping cart.
Thanks for the input Driveshaft!
G
To Fuel Pump Pushrod - Couple questions
