ignitor II
Old Oct 27, 2012 | 05:03 PM
billkat's Avatar
billkat
Default ignitor II
1972 coupe with 1969 350 from Impala. Removed the distributor and installed the ignitor II and flame thrower coil. May not have got the rotor back on in the exact position. I marked the distributor and aligned the marks when I reinstalled it. so it will not run. Should I pull the plug and start from scratch ? im not the best at this but not a complete novice. I cant locate a balast resistor, where did they install that. It had a condensor mounted to the coil bracket and ran to the coil.
Old Oct 27, 2012 | 06:03 PM
gcusmano74's Avatar
gcusmano74
The older cars had ballast resistors to feed the coil. The coil only sees 12 volts when cranking. At some point, Chevrolet changed to a resistor wire. My '74 has the resistor wire to reduce the running voltage to the coil. Check the instructions, but I think your new coil is rated 12 volts full time. So you have to run a (fused!) wire from a switched outlet from your fuse box to the coil, to give it 12 volts full time.
To get the engine running again, you may have to go back to the basics. Set the crank to #1 TDC and make sure the rotor is pointed to the correct distributor tower. Probably, the engine will start with the timing a bit too advanced rather than too much retarded. So you could try to "fudge" things a bit in that direction, if it becomes desperate time. After it starts, set the timing correctly right away.
Good luck, buddy. I know there is nothing more frustrating than to spend a bunch of time on a project and have it not work.
Old Oct 27, 2012 | 06:10 PM
Mike Ward's Avatar
Mike Ward
on the compression stroke.........................
Old Oct 27, 2012 | 07:03 PM
billkat's Avatar
billkat
I pulled No. plug and got it on compression stroke and got the markes lined up. Put the distributor in and still wont crank. Put the points back in and wont crank. It fired up before I put the iggy in. I put new water pump and ran it. After getting on no. 1 compression I put the distributor back in per my manual and set point gap but still wont run.
Old Oct 27, 2012 | 09:49 PM
oldalaskaman's Avatar
oldalaskaman
we need to see a pic
Old Oct 27, 2012 | 10:00 PM
MelWff's Avatar
MelWff
Can you clarify, the engine cranks but wont start or it doesnt crank at all? If it doesnt crank at all it sounds more like a battery problem, did you disconnect the battery when you installed the ignitor? Are you sure you didnt reverse the wires going to the coil?
Old Nov 1, 2012 | 06:36 PM
72Sprint's Avatar
72Sprint
Dad and I had a similar weekend project when they were visiting - at first it wouldn't crank but then 'we' remembered to put the clutch in...
As far as setting the timing - there's a CHANCE that the first time you ran it to the compression stroke and set it, the rotor wasn't at the right spot to be pointing directly at #1 wire, or something. We did the compression stroke bit 2xs, second time it started right up. Lars' write up really made it quick and easy with the rotor walking method explained instead of screwing with a screwdriver on the oil pump.
I have a tag-on question regarding the ballast resistor - I have 2 wires from PO, or original (dunno) - the red cloth-covered resistor wire, and a black, 12 gauge wire run into the same orignial looking connector for the coil - combined, 14Vs in 'on', didn't test when engine was just running - is this the normal resistor wire setup, or did a PO run a 2nd IGN wire for me already?
Old Nov 1, 2012 | 09:39 PM
gcusmano74's Avatar
gcusmano74
The coil normally has two "hot" wires. The first wire delivers 12 volts to the coil. It is connected through the starter relay and is only live while the starter is running. The stock coil is only rated for 12 volts for a short period of time. The second wire is the resistor wire. It is connected anytime the ignition switch is "On" and the engine is running. The resistor line delivers much less voltage to the coil on a continuous basis. The so called high voltage coils can deliver a hotter spark because they are designed to run full time on 12 volts.
Old Nov 1, 2012 | 11:27 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
The coil is rated for 12 volts for the life of the car (after all, it easily deals with hundreds and thousands of volts every dwell period). What it (and the points) are not rated for is high current. A very different thing. The Ignition Physics sticky at the top explains the function of the ballast resistance and the starter shunt circuit.
To ignitor II
