Doug's headers/side pipes
Has anyone had issues with installing them when using Steeriods R&P?
Also any other clearance or quality problems with them.
I have a '68 NOM big block convertible with TKO,poly mounts, and no P/S.
No dents no dings and they clear everything. We tried Hedman side exit which are only 1 3/4" tubes and they were a nightmare. They didn't clear the pitman arm at all and the collector was angled at the ground. Mean while there are several cars on this forum running those Hedman's with no issues (that's why we tried them). I also tried a well know SS brand of side exit headers and they didn't work either. They didn't clear the pitman arm or steering box. (On a side note they took them back and gave a 100% refund because they are a great company. I can't say the same for Hedman but I will tell you I'll never buy another product from them.)
What ever brand you buy make sure you can return them if they don't fit as long as you don't "ding" them. It seems there is no guarantee that reguardless of what brand headers you buy they are going to bolt on with no issues. Good luck with what ever brand you choose.
I purchased them about 3 years ago and they where on backorder for months. I later found out they where relocating their manufacturing down to Mexico, so looks like I got one of the first from there.
The left side needed clearancing for the steering shaft (I expected that) and the frame. The right side clears everything however the collector is angled at the ground and towards the frame. It looks like the collector has not been welded on straight.
Before I start cutting and re-welding these pile of pipes I thought I would look at Doug's headers.
