Thanks Ricky. Minilites makes 15 x 9"s with 3-13/16" backspacing as an option. I'm leaning toward that. I'm guessing that would work if 4 to 4.5 backspacing fits.
Hi.
I put 255/60x15s on my 75 front and rear using 4.25" offset Crager SS wheels. I ended up using spacers between wheels and hubs to clear the brake calipers.
No i have ordered 4,5" backspace (0 offset) for my 9x16.
I already have this size and offset on my rather ugly Remotec BMW rims (with spacers) for my track tyres and they work just fine with the moved parking brake bracket.
If one is running a single blade fiberglass it may be a tight fit with 4,5" backspace..
Check out this website. You can compare tire/wheel sizing. For example, I can input OEM specs on the left side then whatever to compare on the right. Below it will show you what the difference in fender/suspension/wheel wells/speedo difference, etc. Thought you guys might find it useful.
