I bought a 73 project and I'm pretty sure I want to put a ZZ4 crate motor in it (it has an empty engine bay currently) Will it fit with a dual plane manifold and low profile air cleaner? I plan on installing steroids rack also.
I bought a ZZ4 this past winter. Fits with no issues. I have the manifold that it comes with, a 670 Holley SA, and a 3 inch K&N Air Filter. Shouldn't be a problem.
I put one in my 71 years ago. There are a few issues, but not with fitment. You will have to relocate the temp sender to the intake, the HEI distributor requires some different wiring than points, you will need a new flywheel if the car is a manual, and the water pump will need to be changed or a new accessory drive purchased to keep the ZZ4 pump.
If an auto, the flywheel comes with 10 3/4 inch bolts, not 11 1/2. Can't remember the exact dimensions but it comes with a smaller bolt pattern than the stock torque converter. I ended up getting a smaller dimension torque converter (B&M 2100 Hole Shot) and a new starter.
If your inclined to do some work I would do the zz4 short block and install your own top end making it a zz430 or even more with a little research that way you have gobs of streetable power for not much more.
I installed the "Turn Key" ZZ4 355hp came with serpentine belt system in my 1974 had to flip over the "lower belt roller" on passenger side to avoid hitting a-arm (simple fix). I installed HTC hedman headers (long) had to dimple (very small) one tube on passenger side to get mounting bolt in one place. Went with DeWitt aluminum radiator with electric fan kit.
All in all happy with the over all project.
Also:
installed electronic tach (76)
did blower motor upgrade also (92) motor with fan blades. used 3/4" solid plastic for spacer and noticed improved air flow.
Wanting to change out 4-speed transmission to 5 or 6 speed, 3.73 rear end is not highway friendly on road trips 60mph at 3100rmp.
Reason: add info
