Parking brake backing plate, need help!
I see that I need to pull the axles, but I am not sure how. I was thinking of taking the differential cover off and hoping there was a pin or something? Is there something that I can take off without taking the diff cover off? I bought 3 valvoline 80w90 and the GM posi additive so I do want to change that *****.
Any advice is appreciated.
Thanks!
Thanks!
Why do you want to change the backing plate?
What you need to know before you start is that in constructing the trailing arm they start with the backing plate an build everything else around it.
Virtually everything comes off (spindle included) before the backing plate comes off
Diff cover? backing plates?
What exactly are you trying to do?
Mooser
The car does seem to be almost built around the backing plates, but I think I figured it out. It looks like there are 4 bolts and nuts that hold the hub/wheel bearing together along with the backing plate and axle which seem to be about 6 inches long. I could not get them loose when I tried turning the nuts on the backing plate side, but I will try the bolt heads by the axle side, which I just discovered.
I will flush the differential out after. I bought 3 quarts of valvoline 80w90 and GM posi additive. Is the fill plug on the passenger side about halfway down on the diff? Also do I drain that by just loosening the bolts for the cover and let it leak out or is there a gasket that needs replaced once I crack it open?
I was following these directions when I discovered step #2 or 3 has the bolts heads to release the backing plates from the axles and wheel bearing/hub: inside trunion carrier yoke had me looking hard for a minute and on the outer end I saw the bolts for hub removal to remove the backing plates, I think.
Axle Driveshaft
REMOVAL AND INSTALLATION
1979 and Earlier Models
1. Jack the rear of the car up and support
with jackstands.
2. Disconnect the inside trunnion from the
carrier yoke.
3. On the outer end, bend down the locktabs
and wire-brush the bolts.
4. Scratch a mark on the camber adjusting
cam and the bracket to permit realignment.
5. Loosen the camber adjustment nut and
turn the cam so that the eccentric end points
inward. Doing this will push the trailing arm
out and give more room for driveshaft re
moval.
6. Remove the driveshaft, outside end first.
7. To install, position the inside end of the
driveshaft in the carrier yoke and asemble Ubolts
or clamp and bolts. Torque the bolts to
14-18 ft. Ibs.
NOTE: When removing and installing both
axle driveshafts, be certain to position the
carrier side yokes so that the trunnion seats
are at 90° angles to each other.
8. Install the outside end of the driveshaft
into the spindle drive flange. Install the locks
and bolts. Torque the bolts to 70-90 ft. Ibs.
and bend the locktabs up.
I think you'll find that, among other things, the axle needs to be pressed off/on to replace the backing plate. That's a tall order even for those of us that have done it before. (note: the "driveshaft" removal instructions you have above are not referring to the same stub axle that is contained in the trailing arm.)
If your backing plates are toast, you'll need to take the rear spindles apart and you might as well do the bearings while your in there.
Before you get in any farther you might want to look up what's involved in doing the rear spindles.
As for the diff, since the cover is a structural part of the rear suspension you can't really just loosen off the bolts and drain like a regular chevy.
If it's on the car, siphoning it out of the fill hole is the normal(?) method
Just as a tip, when re-filling the diff, stick a pin through the hose and bottle lid to lock it on, there was a fellow here a few weeks back who dropped the tube into the diff and couldn't fish it back out.
HIH
Mooser
FYI: if you have more money than time you can buy the assembly rebuilt - bolt on and be done.
Thanks again!
In the end the whole rear end is being rebuilt which the car really needed and I am sure my brother will appreciate it.
Does anyone know how to correctly shim the trailing arm mounting bolt?
Also I was thinking about getting a 6 ton shop press for $65 to remove and install the new bearings if it made things easier or could I just use a 2 jaw pulley puller which seemed to work fine for the pushing the strut rods out instead of a spindle knocker?
The spindles seem to be pressed on the trailing arm and pressed on the wheel bearing hub.
My trailing arm mounting bolts, cotter pins and shims are rusted solid. Here's my shopping list. Plus a sawzall blade.
Timken rear wheel bearing kit $80
Spindle support studs 8 22
Spindle support stud nuts 8 2.5
energy suspension trailing arm bushing set 21
6 ton shop press 65
trailing arm front shim pin 2 3.5
trailing arm mount kit 2 66
trailing arm front shim kit 42.5
I found some good videos on youtube:
http://www.youtube.com/watch?v=nZcCn...feature=relmfu
http://www.youtube.com/watch?v=vrAi1...feature=relmfu
http://www.youtube.com/watch?v=c-omV...eature=related
If your parts are rusted enough that you need a sawzall to remove the trailing arms, I'm pretty sure a 6 ton press won't do it. I couldn't get mine apart with my 20 ton press. I had to take it over to a buddy who has a 50 ton press to get it apart. And yes I had decided it was either going to come apart or break. It came apart.
Rebuilding the bearings on these cars is probably the most technically complicated procedure on the entire vehicle. My advice is remove the trailing arm and send it to an expert like Van Steel to have it rebuilt. Then bolt it back on. This is not a job for an average mechanic.
I at least got the trailing arm nut off today after letting it soak for a week in pb blaster, but the bolt won't budge. I beat the end with spike and sledge hammer but just deformed the end of the bolt. I tried beating on the rusted shims which seem to be the main problem because they are rusted pretty good to the frame. Very slow progress unless you guys have a better idea?
If you can't pull the shims out you need to go through them as well as the bolt.
The shims are just mild steel, the bolt is grade 5 (I think, maybe 8) so they cut easily with a sawsall
Blades, I like lenox, but hard to find at the box stores sometimes, I used Milwaukee
Their TORCH blades are very good, and they make a new Double duty one that's got a stronger spine.
Here's a recent thread
http://forums.corvetteforum.com/c3-t...arm-bolts.html
HIH Mooser
Rebuilding the bearings on these cars is probably the most technically complicated procedure on the entire vehicle. My advice is remove the trailing arm and send it to an expert like Van Steel to have it rebuilt. Then bolt it back on. This is not a job for an average mechanic.[/QUOTE]
The original bushings are flared in place which will need to be drilled out vs. pressed (then you can pull/press them). You'll never install original bushings (and properly flare them) using a 6 ton press so waste of money in my opinion.
As others have advised, you've picked the most difficult repair on the car to start with. You can save yourself purchasing many high dollar, single use tools, by simply purchasing a rebuilt unit and installing it.
And yes, the trailing arms can be a b**ch to remove. Most of us have been through it. Hang in there. It CAN be done! Good quality sawzall blades, and a lot of beer.
I finally made some good progess last night and got one trailing arm out. It took a long time to cut through the shims and the bolt, but shaving by shaving they came off. I bought another set of sawzall blades with more teeth per inch for cutting thick metal which didn't make much of a difference.
Next I need to drill the bushings out, get the spindle nut off and cut the spindle support studs. Then do the same thing to the same thing to the other trailing arm. Plus I want to blast and paint them.
I was thinking of taking them to a local corvette shop in the Pittsburgh area to get new bushings and bearings installed correctly, only if they are charging less than $200 labor, otherwise I may buy a 20 ton shop press from harbor freight and press them in and out myself.
I understand how the bearings are installed correctly with the end play and adjusting the shim to get it correct, but I need to read and learn how the bushings are installed correctly with the flares. Just to make sure that the shop I take them to does the job right or so I can do it myself.
Here's to another trailing arm day.
P.S.
Tough job for an average mechanic for sure, but feel I am a little above average. I mean I don't just do oil changes and brakes occasionally. I have replaced a few clutches and will get involved with any job on any car system. Prior to this backing plate problem, I buffed the paint job, cleaned the engine, did a full tune up, replaced the valve cover gasket, the power brake booster, master cylinder, caliper, front swaybar bushings. Internal engine and internal transmission are the only jobs that scare me at this point.
After this rear suspension, parking brake and differential job, I will fix the headlight vacuum problem, one brake light problem, loose door panel problem, caulk the back window, and install new carpeting. Then see what else.
This car seems a lot simpler compared to my foreign tuner, except the parking brake backing plate.
