68 Corvette Convertible small block or big block?
Old Oct 31, 2012 | 12:03 AM
Hub454's Avatar
Hub454
Default 68 Corvette Convertible small block or big block?
I just bought a 68 conv. and it has the axle code of AV with is a 3.08 posi and was listed as a 427. I am trying to find clues to know if this car was originally a big block. It currently has a 350 4spd. One clue I trying to figure out is the tach. It has orange at 5300 and a redline at 5600 does anyone know is the considered redline tach at 5300 or 5600? The trim tag is missing so i am trying to figure out any other way to identify the engine, color, trim this car came with. It does not have a sway bar on the rear. Any thoughts are appreciated.
Old Oct 31, 2012 | 12:49 AM
RickyBerg's Avatar
RickyBerg
Crawl under the car and check if the rearend yokes coming out from the diff has got the U-clamps (smallblock) or the bolted HD caps (Bigblock).
Anything can offcourse be changed on a car so one can never know for shure but if you have a number of things indicating its a smallblock car its propably one.
Old Oct 31, 2012 | 11:45 AM
Hub454's Avatar
Hub454
Default Rear end caps
The caps look kind of like a u clamp. Do you have any pic of a big block cap?
Old Oct 31, 2012 | 11:51 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Hub454
...I just bought a 68 conv. and it has the axle code of AV with is a 3.08 posi and was listed as a 427...
The AV code is correct for a 68 big block, but your differential may not be original. Big blocks got heavy duty yokes:
...One clue I trying to figure out is the tach. It has orange at 5300 and a redline at 5600 does anyone know is the considered redline tach at 5300 or 5600?...
The red line would be 5600.
...The trim tag is missing so i am trying to figure out any other way to identify the engine, color, trim this car came with...
VIN and trim tag do not identify original engines in the 68s. Trim tag would have codes for the original paint and trim colors and the time/build date. You may be able to peek around door jambs, hood ledges, behind a tail light and find evidence of the original color. Interior color is possibly stock unless you can find obvious evidence of a color change.
...It does not have a sway bar on the rear...
Factory big blocks did, but a PO could have removed the bar at some point in the past. Do your trailing arms have mounting holes for the sway bar link brackets?
What is your VIN?
This is good. Worth the price of a copy:
This is also pretty good:
Order a 68 owner's manual, assembly instruction manual (AIM), and GM chassis service manual for your 68. You're going to want them
Congrats on the 68.
Old Oct 31, 2012 | 12:11 PM
restoman1's Avatar
restoman1
The 5600 red line tach is an indicator of the L36 (427/390) or L68 (427/400) engine.
Ed
Old Oct 31, 2012 | 02:50 PM
Hub454's Avatar
Hub454
Thankyou so much for the help its been great!!!! I have always wanted 68-72 converible and now have one. The thing that makes me wonder on a big block are the Tach, rearend #s, original BB hood. But the yokes are ubolt type.
The challenge is do I leave it be and have fun with a good driver or do I tear it down? I will probably tear it down but dont want it to sit for years unfinished. I am wanting to pull the body from the frame and sandblast/paint the frame. That will probably open up a whole can of worms. The book sugguestion are great and I will order them today. I did get a Corvette 1968-1982 Restoration Guide - Prince 2nd addition but it was just OK.
Old Oct 31, 2012 | 05:12 PM
Hub454's Avatar
Hub454
The VIN is 194678s423521. The Fact Book for 68-72 Stingray is disontinued. Do you know where I can find one? Or a replacement book? Thanks
Old Oct 31, 2012 | 05:41 PM
restoman1's Avatar
restoman1
There are two on EBAY, but sit down before you look at the prices. Amazon also shows a few, but again, try not to have a heart attack when you see what they want for them.
Ed
Old Oct 31, 2012 | 05:48 PM
SuperBuickGuy's Avatar
SuperBuickGuy
sit down? $250 made me sit down for a book for my H3....
https://www.paragoncorvette.com/p-35...fact-book.aspx
but $34.00 sounds pretty reasonable
Old Oct 31, 2012 | 05:54 PM
restoman1's Avatar
restoman1
It is, but that's not the book he's looking for.
Ed
To 68 Corvette Convertible small block or big block?
