horn does not work
Old Nov 2, 2012 | 02:33 AM
newbusa's Avatar
newbusa
Default horn does not work
Okay i replaced my horn with a new one because the old one did work,and i tested it on a 12 volt source, But it still does not work via the horn button,But the buzzer works when i put in the key,So am i safe to realize that the horn relay works?
Just trying to omit some of the parts to trouble shoot.
Old Nov 2, 2012 | 04:13 AM
PhotoVette1's Avatar
PhotoVette1
The contacts on the horn button could be rusty and dusty. That's what I would check first. Then the relay.
Old Nov 2, 2012 | 11:05 AM
robert.sperry's Avatar
robert.sperry
My guess is that the horn relay is bad. The fact that you get a buzz sound when you put the key in the ignition is unrelated to the operation of the horn.
Old Nov 2, 2012 | 07:24 PM
newbusa's Avatar
newbusa
Okay, i assumed the warning buzzer was part of the horn relay switch.So on the 68 C3 is the horn relay under the hood or under the dash? I will pull the horn cover off the steering wheel and check under it,I presume directly under is the horn contact?
To horn does not work
