Rotor/hub alignment
I just discovered some factory made shims that just slip over all 5 studs and can be clocked or stacked to correct this problem.
http://www.nucap.com/products/solutions/brake-align/
I haven't tried these yet, but they look like they should work.
Per the manufacturer, they are sold through Napa. They relabel them and call it the HUB CORRECTION PLATE and it is listed under their UP line code.
This should reduce the rotor run out.
It will be awhile before I get around trying this, so if anyone else tries, or has tried this, post up you results
Make sure you get the correct set of shims, ie. lug pattern. The freebies I got from my neighbor were not corvette specific so they did not fit the lug pattern and I had to trim them to fit. It worked out fine but was a hassle. Using these shims I got to about .002 runout on each wheel. If they are the same ones you can get at NAPA I'd say give them a shot. If your runout is really bad I would recommend an on car lathe because stacking the shims too thick may cause brake pad clearance issues, but that would be a pretty extreme case I think.
