LS5 454 Oil Pressure Normal Operating Range
Old Nov 9, 2012 | 12:31 PM
Vetteman25's Avatar
Vetteman25
Default LS5 454 Oil Pressure Normal Operating Range
Cold and hot. Idle and at speed. Oil Pressure ranges between 65-70 PSI. 454 was rebuilt, to my knowledge and documentation from the previous owner to 100% original specifications. I have owned other BB cars before but was not sure if this is a characteristic of the vette having a high volume oil pump from the factory, or the rebuilder installing a high volume oil pump because he thought it was the way to go.
Correlating symptom possibly associated with the high pressure is small oil leak at the oil pan.
Craig
Old Nov 9, 2012 | 01:29 PM
MelWff's Avatar
MelWff
What viscosity oil are you using?
Old Nov 9, 2012 | 01:42 PM
jnb5101's Avatar
jnb5101
i have a high volume melling pump and use 40w oil. it pegs the meter until it warms and then settles at 30, even at idle.
Old Nov 9, 2012 | 02:32 PM
Vetteman25's Avatar
Vetteman25
I use 10W-30...at idle it is at 65. At speed it is pegged at 70. No matter if it is cold or hot
Old Nov 9, 2012 | 03:51 PM
MelWff's Avatar
MelWff
First check if your gauge is reading correctly by installing a temporary unit to verify.
Old Nov 9, 2012 | 06:29 PM
bigvette1's Avatar
bigvette1
I have a 454 rebuilt with a Melling HV. Cold at fast idle it pegs the gauge as yours does. Hooking up a temp gauge the pressure is right a 70 psi when cold. When fully warm at idle it runs 30-35 psi. Your engine is acting the same.
Old Nov 9, 2012 | 09:22 PM
flyeri's Avatar
flyeri
With 10w-30 I have maybe 50 cold. Warm it is 20-25 at idle and 35ish under power.
Old Nov 9, 2012 | 10:56 PM
exposingtime's Avatar
exposingtime
2015 C3 of the Year Finalist
sorry to hijack your thread a bit, but its on the same topic.
My oil pressure is fine. Reads around 40 psi at idle and around 55 psi on acceleration. 427 390 horse.
My gauge reads at around 5 psi with the engine off. Is there any way to adjust it?
Gary
Old Apr 7, 2013 | 09:15 PM
vetteman454's Avatar
vetteman454
I've only owned my 74 LS4 for year now. The oil pressure is 80 psi cold and drops to 70 or so at operating temp. I think normal is around 45 psi.
Old Apr 7, 2013 | 09:23 PM
couperdecar's Avatar
couperdecar
I have pretty high oil pressure too. I was told that a really good oil filter will do this. I've been tempted to stick on a FRAM just to see if it'll come down. What are you running for a filter?
Old Apr 7, 2013 | 10:43 PM
early shark's Avatar
early shark
My '71 LS6 cold idles around 68, at warm idle is 34 and at running speed 55mph is just above 50, and climbs as I accelerate! Using Brad Penn 10w 40 and using WIX filter 51061.
Old Apr 8, 2013 | 12:06 AM
Bagmup's Avatar
Bagmup
Chevys always have good oil pressure. The Aussie built 308 V8s, the oil pressure warning light flickers at idle.
Old Apr 8, 2013 | 07:07 AM
vetteman454
I'm using Valvoline 10W30 with AC Delco filter. I have used this in smallblocks regularly and had 40 psi pressure.
Old Apr 8, 2013 | 08:10 AM
roger3's Avatar
roger3
71 LS-5 with 63,000 miles. Never been rebuilt.
10W30 Oil.
60-psi cold at idle, once warmed pressure drops to about 20-psi at idle and about 35-psi when cruising.
Roger
Old Apr 8, 2013 | 10:35 PM
vetteman454
This could be a bad sending unit or pressure gage. What's the best way to troubleshoot this? Replace the sending unit first or is it more likely to be the gage?
To LS5 454 Oil Pressure Normal Operating Range
