Hi 7T1,
Are you sure about the relationship between bolt length and body drop?
My experience was that the body dropped 1/2 the increase in bolt length, (not twice the increase), because the center point of the spring stays mounted at the same point, and the bolt end of the spring is traveling in an arc.
Isn't that the reason some people feel they need to go beyond the 8" bolts and have problems with the even longer bolt touching the wheel or tire?
Regards,
Alan
I measured mine and I am a whopping 32" to the bottom of the fender lip to the ground. One hell of a off road vette... I agree that I think she will drop some driving, not sure that much! I would be ok with it around 28" in the rear, the font I am ok with and think she will settle ok there. Considering this 10" bolt but does anyone know where to fit it? I think the one that came in the kit is 8".
I agree, I think the 10" bolt will allow the arm to rest higher in the wheel well. I would think a 10" bolt would gain you about a 1.5" drop in the ride height. Guessing...
mine is 28'' in rear but looking to get it down a little more after putting on new 17x8 wheels,i think the 10'' bolts will do it. but i,am not sure.
Hi 7T1,
Regards,
Alan
Somewhere around 1/2 - 2/3 of the length change (closer to 1/2)
One of the big "concern" with the 10" bolts seems to be that they are hanging below the rim at that point and if the tire went flat would/could touch the pavement.
The move to a 17 or 18 inch rim would help this, but would also help close the gap between the wheel and fender anyway.
I'm not sure if the arc geometry would be off in this case since the car is sitting soooo high the half-shafts must be going on a fair angle now so the longer bolts would just bring the rear down to where it "should" be so the geometry should actually be better....but I'd have to actually sit and think about that before I was sure.
I measured my '78 last night.
I'm sitting at about 27.75" from ground to fender lip. Thats with a VBP suspension and 255/60/15
All final suspension torques are completed with the wheels on the ground.
Absolutely correct. As a matter of fact, you shouldn't torque them at all untill the suspension is at normal ride height. Leave them one turn loose until you have full weight of the the car down on it's tires, and the suspension has completely settled.
The factory rubber suspension bushings don't rotate as the suspension moves. They just twist up and down. You tighten them at the regular ride height so you are positioning the bushings in the center of their travel. If you tighten the bushings with the wheel at full droop, you will twist the bushings past the amount of movement they are designed to accomodate when you drive it. They won't last as long as they should.
This is my ride height using a shortened VBP 330lb spring, 10" C4 link bolts and double offset trailing arms (to allow sufficient spring to rim clearance).
The rims are 18 x 9.5 with 5.25" backspace.
