1981 vette how do i remove the bottle washer motor from the bottom
Old Nov 13, 2012 | 02:27 AM
Dmossy96's Avatar
Dmossy96
4th Gear
Default 1981 vette how do i remove the bottle washer motor from the bottom
I need to know how to remove the washer motor from the bottom of the windshield wiper fluid bottle
Old Nov 14, 2012 | 04:19 PM
commander_47's Avatar
commander_47
U have to get a deep well socket, or a crows foot socket, that will clear the screen from the inside of the washer container.
Old Nov 14, 2012 | 04:32 PM
Crash80's Avatar
Crash80
I remember doing that little exercise on my 80. As I recall it involved a six pack of beer...cursing and throwing some tools.
Old Nov 14, 2012 | 05:17 PM
doctorgene's Avatar
doctorgene
Yes Sir; It does come out from the bottom. You just twist it the right way & low & behold it comes right on down. Remember how you twist it, so you can twist it right back into place. You have to be a sport, to own a sports car. Have a great one. Gene
Old Nov 14, 2012 | 06:27 PM
C3 4ME's Avatar
C3 4ME
if it's the same as my 79, and I think it is, there's a little filler panel btwn the wheel well and firewall that you remove. I'd take the washer bottle out myself, so I could see up close what I'm doing. To do that, you just unbolt it and drop it down. The filler neck is a separate piece, and can be separated from the washer bottle from above.
Old Nov 15, 2012 | 07:50 AM
Crash80's Avatar
Crash80
By what he asked, he seems to have the bottle out of the car (I hope, I can't imagine trying to get to it while in the car), he is asking about getting the motor off the bottom of the bottle. Remember fellas, the nut is inside the bottle, though a small hole where the filler neck goes.
Old Nov 15, 2012 | 08:26 AM
commander_47
[QUOTE=doctorgene;1582333560]Yes Sir; It does come out from the bottom. You just twist it the right way & low & behold it comes right on down. Remember how you twist it, so you can twist it right back into place. You have to be a sport, to own a sports car. Have a great one. Gene[/QUOTE
My 81 doesn't twist out.
There is a nut inside the bottle, and over the screen. It is not easy to get to in or out of the car.
Old Nov 16, 2012 | 02:16 AM
Dmossy96's Avatar
Dmossy96
4th Gear
Thanks or the feed back the solution would be to use the long socket extension going into the inside the bottle. My problem was there is a protruding flange which is apart of the bottle and its right in the way you cant turn the washer moter its in the way.
Old Nov 16, 2012 | 08:09 AM
Crash80's Avatar
Crash80
I assume you have the bottle, with attached motor, out of the car. The nut to unscrew is inside the bottle. This is the part where the beer drinking and tool throwing comes in handy. You need a deep socket, an extension and a universal socket joint as I recall, to make this work. I am not sure of the protruding flange you speak of, Got pics?
Old Nov 20, 2012 | 03:55 PM
power shift's Avatar
power shift
I've got hooker side pipes so I had to unbolt the master cyl from the booster and gently push it out of the way to get mine out. Big pain in the a#@#s
To 1981 vette how do i remove the bottle washer motor from the bottom
