big block conversion into a 1968
Old Nov 13, 2012 | 04:46 PM
dpsvette's Avatar
dpsvette
4th Gear
Default big block conversion into a 1968
I am installing a bb into a 1968 coup. Does anyone have any pictures of the engine harness routing?
Old Nov 13, 2012 | 10:14 PM
GDaina's Avatar
GDaina
Should not be any different than a small block..
Also depends if you are using point or T.I. ingnition
Old Nov 14, 2012 | 09:46 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Pretty much the same as the small block. The assembly instruction manual (AIM) shows the factory big block installation.
To big block conversion into a 1968
