Dim dash lights on 81
Old Jun 7, 2002 | 10:34 AM
rmadlem's Avatar
rmadlem
Default Dim dash lights on 81
All of my dash lights are dim on the 81. I've changed the bulbs but that hasn't helped. Is this a grounding problem..or the switch??
Any ideas would be appreciated.
Thanks!! :seeya
Old Jun 7, 2002 | 12:13 PM
Armstrong's Avatar
Armstrong
Default Re: Dim dash lights on 81 (rmadlem)
I have the same problem on my 81 and I even have a new switch cause mine wasn't working when I got the car. I'm planning on going on a grounding safari here in the near future. Maybe even this weekend. Everything else works great as far as electrical goes well mostly anyway :lol: If I do find the prob I'll be sure and post it.
Old Jun 7, 2002 | 01:22 PM
weendoggy's Avatar
weendoggy
Default Re: Dim dash lights on 81 (Armstrong)
We are the original owners of our '81 and I still don't like the dash lights. By today's standards they are a little on the "light" side, so to speak. I can read them fine with lights on and dimmer turned up but in my other vehicles they are much brighter. Because they've always been that way I don't worry about them much. I've checked grounds before and everything is just fine. A lot depends on how dim is dim as well. Maybe your's are dim and mine are normal, who knows.
Old Jun 7, 2002 | 07:49 PM
Ben Taylor's Avatar
Ben Taylor
The problem is that you've seen dash lights in a newer car, all old cars have dimmer lights.
Old Jun 7, 2002 | 08:01 PM
82dukman's Avatar
82dukman
Default Re: Dim dash lights on 81 (Ben Taylor)
Mine were also dim AFTER i replaced the bulbs/switch. take a can of WD-40 and with the rod pulled out, spray some into the opening. Then rotate the **** around. You are basically cleaning the rheostadt. this might help.
Old Jun 7, 2002 | 09:49 PM
rmadlem's Avatar
rmadlem
Not quite. I had a '78 SA that had much brighter dash lights than this. These can't be seen at night because they are so dim....so it's not that I'm used to newer cars. :rolleyes:
Old Jun 7, 2002 | 09:50 PM
rmadlem's Avatar
rmadlem
Default Re: Dim dash lights on 81 (82dukman)
Thanks!! I'll give that a try. :seeya
Old Jun 8, 2002 | 02:25 AM
Stevo81's Avatar
Stevo81
I have an 81 but have not arrived at the driving at night stage yet. Will smog next week. Anyway, while I was talking to the Psychic Friends Network, I wondered if these lights might be changed to halogen...
Old Jun 8, 2002 | 08:11 AM
Ybnormal's Avatar
Ybnormal
This must be common because I have the same problem on my 81. I was thinking a ground problem also. If you do find a problem please let us know what you find and I will do the same.
YBnormal..Drive a Vette
Old Jun 8, 2002 | 07:30 PM
terry82's Avatar
terry82
my 82s not bright but can be seen okay at night.wonder if there is a diferent bulb you could go to .can you check voltage coming out of the light switch?
Old Jun 8, 2002 | 07:33 PM
corvgreg's Avatar
corvgreg
Emerging Vendor
Default Re: Dim dash lights on 81 (terry82)
I agree on checking the voltage on the switch.
To Dim dash lights on 81
