big block pix; is this normal?
Old Nov 13, 2012 | 07:34 PM
learje's Avatar
learje
Default big block pix; is this normal?
might look at this block tomorrow. does it look right where i added the arrow on the pix?
thx!
Old Nov 13, 2012 | 07:37 PM
jyounane's Avatar
jyounane
Looks like very bad news to me....
Old Nov 13, 2012 | 07:47 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
A hole in a block is not good
Old Nov 13, 2012 | 07:57 PM
7t9l82's Avatar
7t9l82
dont let your crazy neighbor tell you you can put j.b weld on it. its done
Old Nov 13, 2012 | 08:36 PM
Ironcross's Avatar
Ironcross
A young Garlets would just glass it up and get a few more runs out of it.....
Old Nov 13, 2012 | 09:06 PM
learje's Avatar
learje
thats what i thought , thx!
Old Nov 13, 2012 | 09:20 PM
gcusmano74's Avatar
gcusmano74
What you have there is an artificial reef. Drop it in the ocean.
Old Nov 13, 2012 | 09:53 PM
Hammerhead Fred's Avatar
Hammerhead Fred
PM sent
Old Nov 14, 2012 | 11:10 AM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Going to be pretty hard to keep coolant in that block
Old Nov 14, 2012 | 11:21 AM
bashcraft's Avatar
bashcraft
A can of stop leak will fix it right up.
Old Nov 14, 2012 | 11:34 AM
wcsinx's Avatar
wcsinx
I'm just trying to figure out why someone bothered to clean up a block with a big freaking hole in it. Gonna make a coffee table Top Gear style out of it?
That block is FUBARed dude. Move along.
Old Nov 14, 2012 | 12:06 PM
7t9l82's Avatar
7t9l82
Originally Posted by ironcross
a young garlets would just glass it up and get a few more runs out of it.....
garlits
Old Nov 14, 2012 | 02:51 PM
Mooser's Avatar
Mooser
Especially if you just jam the whole can into that hole.
Old Nov 14, 2012 | 03:35 PM
1955pirate's Avatar
1955pirate
Default bubble gum?
Chewin' up a big jawbreaker bubble gum may suffice until something better comes along. Or, run it without coolant to prevent pressure build up.
Old Nov 14, 2012 | 04:16 PM
SuperBuickGuy's Avatar
SuperBuickGuy
hmmm, look at all the naysayers... anything can be fixed with enough time, money and materials. Even that hole could be fixed; but the question is, is it worth it to fix it? You could spend, literally, thousands of dollars welding then re-machining the block.... but cast CAN be welded, and actually it's pretty easy to do.
Old Nov 14, 2012 | 04:24 PM
MotorHead's Avatar
MotorHead
They fix windowed Donovan, Keith Black etc blocks because they are expensive racing blocks, no point in fixing a $200 OEM block when there are thousands out there to be had.
Old Nov 14, 2012 | 05:07 PM
wcsinx's Avatar
wcsinx
Yeap
priced out labor costs lately?
To big block pix; is this normal?
Old Nov 14, 2012 | 05:22 PM
Ironcross's Avatar
Ironcross
Originally Posted by 7t9l82
garlits
your right thanks, how did I miss that....I guess I could correct it....but
Old Nov 14, 2012 | 06:40 PM
FreshSelect's Avatar
FreshSelect
do the coffee table, check mine out!
of course i used a ls1 aluminum block since it wont rust
Old Nov 14, 2012 | 06:59 PM
Crepitus's Avatar
Crepitus
The aluminum block is a LOT easyer to fix
