Power steering pump removal
Old Nov 15, 2012 | 07:49 PM
AT-82Collectors's Avatar
AT-82Collectors
Default Power steering pump removal
I am trying to remove the power steer pump on my ’82 with a ZZ4 engine without much success. I have lines loose, the one bolt and two nuts from the studs out. Problem is it will not come out of the bracket. I have tried double nuting (is that a word?) the studs to remove them with no success. The pulling is hitting the cross member not allowing it to come out. Do I have to remove the pulley before it will come out or perhaps try and remove the bracket?
Any help will be very much appreciated.
Andy
Old Nov 15, 2012 | 07:55 PM
74 LS4-454's Avatar
74 LS4-454
Finalist 2020 C4 of the Year - Unmodified
Andy, if I remember correctly, there are 3 attachments to the pump, I had to loosen all 3 to change the PS belt on my 82. I would assume you have to do the same to remove the pump, look for the 3rd nut and or bolt..... unless w/ the ZZ4 it is attached differently........Tom
Old Nov 15, 2012 | 08:10 PM
AT-82Collectors
Thank you Tom, yes I have the one bolt and two nuts removed. I can move it around in the bracket, just not enough to get the pump out.
Old Nov 15, 2012 | 10:07 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Remove the 2 bolts holding the bottom "cradle" bracket and remove as an assembly.
Old Nov 16, 2012 | 11:46 AM
AT-82Collectors
That worked KapsSA, I was not sure if I need to get the pully off or the bracket.
Thanks much, back on the road again
Andy
To Power steering pump removal
