Quadrajet mixture screws
Old Nov 16, 2012 | 03:25 PM
Street Rat's Avatar
Street Rat
Default Quadrajet mixture screws
I was adjusting the mixture on the Quadrajet today. 10 turns out to achieve the best vacuum at idle. That seems quiet excessive to me. Is that about the normal amount of turns you guys get? The car is an 81 with headers. The computer carb is gone and the motor is stock other than the exhaust. I plan on sending the carb off to Lars when it get some spare cash. The carb has a 79 ID number. I'm not running the computer either.
Old Nov 16, 2012 | 03:33 PM
MelWff's Avatar
MelWff
Sounds like way too much. Have you tried turning one screw 1/8 turn clockwise, check if the idle speed drops, then if not turn the other screw 1/8 turn. Continue this till you get a drop and then turn the screws back 1/4 turn.
Old Nov 16, 2012 | 03:45 PM
Street Rat's Avatar
Street Rat
The carb was set at 11 turns out when I started adjusting it. I took the screws all the way in and started at 5 turns out. I tried starting it and it wouldn't run. I turned each screw out in half turn increments until it started and idled. That didn't happen until I got to 8 and a half turns. The vacuum was at 14. It's at 18 with the mixture screws out 10 turns.
Old Nov 16, 2012 | 03:52 PM
MelWff's Avatar
MelWff
have you tested for a vacuum leak? Try spraying some carburetor cleaner around the base of the carburetor and see if the vacuum reading changes.
Old Nov 16, 2012 | 04:15 PM
Street Rat's Avatar
Street Rat
No I haven't. I'll have to try that tomorrow. I'm out of time for today. Thanks for the responses.
Old Nov 16, 2012 | 09:06 PM
REELAV8R's Avatar
REELAV8R
One of the mods I made on my q-jet when I rebuilt it per Cliff Ruggles book was to drill the idle screw holes larger. This makes the idle screws more sensitive to adjustment. Mine are now 3 1/2 turns out for best idle. You may want to try it. you'll have to take the carb off to do it or you may get metal in the intake.
Old Nov 16, 2012 | 09:40 PM
Tim H's Avatar
Tim H
Yes that is an excellent suggestion !!!!!
Old Nov 17, 2012 | 06:51 AM
gcusmano74's Avatar
gcusmano74
Yes, but only just SLIGHTLY larger. Read Cliff's book first, or send it to Lars. If you make the holes too large, you will lose the fine flow control that you need. You will have to find another throttle plate and start over.
Don't ask me how I know. I hate to talk about it.
Old Nov 17, 2012 | 11:36 AM
REELAV8R's Avatar
REELAV8R
gcusmano74 is correct, only slightly larger. I have in my notes that the hole was originally .082" and that I changed it to .090". Small change= big difference.
Old Nov 21, 2012 | 09:38 AM
Street Rat's Avatar
Street Rat
I sprayed carb cleaner around the base gasket and the attached vacuum hoses. No change in vacuum or rpms. I've got some other issues with this carburetor. Hard starting, long warm up time (choke issue), and a bog in the transition from idle to part throttle. So I'm packing it up and sending it to Lars.
Old Nov 21, 2012 | 10:44 AM
Jeff_Keryk's Avatar
Jeff_Keryk
Vacuum Leak Test - Lars taught me a simple test. At idle, back out idle speed screw all the way (to close throttle blade). If idle speed does does not idle down and die, you have a vacuum leak. Air must be getting in somewhere.
Old Nov 21, 2012 | 11:37 AM
Shark Racer's Avatar
Shark Racer
FWIW this may not hold true if you're running a carb with a decent amount of idle bypass air.
Also, to the OP - do you have a non-computer controlled distributor installed as well?
Old Nov 21, 2012 | 12:25 PM
Street Rat's Avatar
Street Rat
Computer controlled carb and distributor have been replaced with pre-81 units. Computer is not connected to anything.
To Quadrajet mixture screws
