Which speedometer cable to use - 78
Old Jun 7, 2002 | 04:36 PM
4rensic22's Avatar
4rensic22
Default Which speedometer cable to use - 78
My cruise control transducer is FUBAR. I bought a 1-piece cable from NAPA, supposedly for a 78 w/o cruise. The cable is 5 feet long, which looks to be a few feet too short. Anyone else run into this?
Old Jun 7, 2002 | 05:04 PM
ylose's Avatar
ylose
Default Re: Which speedometer cable to use - 78 (4rensic22)
I'm redoing mine soon, have the cable....I'll watch this thread and also post what I find...I too have the cruise/transloser but I am bypassing it with the one-piece. :cheers:
Old Jun 7, 2002 | 05:54 PM
Andrew's Avatar
Andrew
5 Feet long sounds about right for my 79 w/o cruise. I have a manual transmission though. I'm not sure if the connection to the transmission is the same between the auto and manual.
Are you going to bypass the cruise control? If so, I would think that cable would work.
Old Jun 7, 2002 | 06:00 PM
TravMsns's Avatar
TravMsns
Default Re: Which speedometer cable to use - 78 (Andrew)
Where is the cruise control tansducer? I removed all my cruise control stuff from the engine compartment, including that little box near the wiper fluid reservoir. Since then, my speedometer reads like 100 when I'm doin 50, I'm thinking removing all the cruise stuff had something to do with it. So I think I'm gonna need to bypass the transducer as well. Where the heck is it located?
Old Jun 7, 2002 | 06:03 PM
Pete79L82's Avatar
Pete79L82
For 1978
For all automatics w/o cruise - 1550mm (61")
For L-48 manual w/o cruise - 1550mm (61")
For L-82 manual w/o cruise - 1800mm (70.87")
Old Jun 7, 2002 | 08:41 PM
4rensic22's Avatar
4rensic22
Default Re: Which speedometer cable to use - 78 (TravMsns)
Cars with cruise control have a two - piece speedometer cable. Where the two sections of cable meet is at the transducer. It is located on the driver's side on/near the inner fender skirt - near the washer fluid reservoir.
[Modified by 4rensic22, 7:44 PM 6/7/2002]
Old Jun 7, 2002 | 08:42 PM
4rensic22's Avatar
4rensic22
Default Re: Which speedometer cable to use - 78 (Pete79L82)
Thanks, Pete.
To Which speedometer cable to use - 78
