A/C delete 1977
Old Nov 24, 2012 | 11:04 AM
1977L48's Avatar
1977L48
Default A/C delete 1977
i am looking to remove the A/C evporator core and box from my vette. i already removed the compressor and condenser. i cannot see all the bolts that hold the box onto the firewall. does the front clip have to come off the car to remove it? also what all has to be changed to make my car appear it never was equipted with A/C. i know getting a heater only air box and the controls on the center console. i am really looking to improve on the space in the engine bay and put the car on a diet!
Old Nov 24, 2012 | 11:07 AM
'75's Avatar
'75
You'll have to remove the right lower dash pad and remove the nuts from the inside of the car.
Old Nov 24, 2012 | 11:13 AM
Scottd's Avatar
Scottd
Dont let the inner work scare you. Removing the AC box will free up what appears to be MILES of space in your engine compartment. I gutted mine and never looked back. Pulled all the ducting too.
Old Nov 24, 2012 | 11:17 AM
1977L48's Avatar
1977L48
i just need to find a heater box, it gets cold in southern alabama. also will i need a different heater core when i switch to the heater box?
Old Nov 24, 2012 | 12:50 PM
John 65's Avatar
John 65
After I removed mine, I glassed the area smaller for a heater box a friend gave me from his 69. Ducting went also, really want to make the car as simple as possible.
Old Nov 24, 2012 | 03:22 PM
1977L48's Avatar
1977L48
Will i have to do that?
Old Nov 24, 2012 | 03:36 PM
BKbroiler's Avatar
BKbroiler
I removed all the AC stuff from my 77. There was one bolt to be removed from inside the car and it can be reached by pulling the rug down. I covered the evaporator housing opening with a cover from ACdelete.com. Pricey but effective. The original heater core works with this cover and it will accept the stock fan. I don't use my heater here in Jersey and its fine for temps in the 40s, with the sun shining.
Old Nov 24, 2012 | 07:10 PM
73C34me's Avatar
73C34me
I have a complete inner and outer box with blower motor and ducts from my 73 for sale.
QUOTE=1977L48;1582405045]i am looking to remove the A/C evporator core and box from my vette. i already removed the compressor and condenser. i cannot see all the bolts that hold the box onto the firewall. does the front clip have to come off the car to remove it? also what all has to be changed to make my car appear it never was equipted with A/C. i know getting a heater only air box and the controls on the center console. i am really looking to improve on the space in the engine bay and put the car on a diet![/QUOTE]
Old Nov 24, 2012 | 07:29 PM
johnt365's Avatar
johnt365
I went the ACdelete.com route as well. You can keep your existing heater core. Using a 2in hole saw you can relocate the fan resistor as shown.
all kinds of room now
It is not a plug and play solution but its pretty close. You may have to take a Dremmel to it on the side that touches the fender and I used some black caulk to seal it. It works for me. I like the cleaner look.
Old Nov 24, 2012 | 09:04 PM
1977L48's Avatar
1977L48
Thanks, i ordered mine today. I just have to figure out how to get to the bolts on under the fender, i can barely reach them
Old Nov 24, 2012 | 10:28 PM
BKbroiler's Avatar
BKbroiler
There is a removable panel (horizontal) just behind the front wheel below the evap housing. Take that off and reach up.
Old Dec 11, 2012 | 04:42 AM
nz corvette's Avatar
nz corvette
Hi Guys,i am looking at removing the a/c gear too, how do you do that? any problems with the liquid in hoses etc,also there seems to be a relay box beside the trans dip stick is it a/c related? any help would be great!
cheers Dave - New Zealand
To A/C delete 1977
