alum roller rockers
Old Nov 24, 2012 | 07:07 PM
69small block's Avatar
69small block
Default alum roller rockers
any one had a problem with alum. roller rocker arms rubbing on valve cover
Old Nov 24, 2012 | 07:41 PM
BlackC3vette's Avatar
BlackC3vette
You can buy a 1/4" spacer to give you more room under the cover.
Old Nov 24, 2012 | 08:13 PM
drwet's Avatar
drwet
You need the tall valve covers with roller rockers.
Old Nov 24, 2012 | 08:57 PM
Phil Zell's Avatar
Phil Zell
Some rub, some don't. I use the thick gaskets with stock valve covers. The rockers are 1.5 Crane Gold.
Old Nov 24, 2012 | 10:31 PM
BlackC3vette
http://www.summitracing.com/parts/sc...make/chevrolet
Made to fit under stock valve covers
Old Nov 24, 2012 | 11:41 PM
Ironcross's Avatar
Ironcross
One solution is to double the gasket in the valve cover and essentially remains stock looking
Old Nov 25, 2012 | 08:41 PM
GUSTO14's Avatar
GUSTO14
I have run Crane roller rockers on my '73 since the early 90's with the aluminum L-82 covers and have had no clearance issues. I did switch to the thick FelPros a while back when I replaced the gaskets after the car sat for three years just to add a little extra clearance.
However,
there was a thread on here a few years back about someone having the rockers hit the stock tin covers on his engine. It turns out that he had flipped the covers before installing them (rotated 180 degrees). The factory tin covers are not symmetrical....
The later 350 covers with no writing on then can in fact be installed upside down if one isn't paying attention.
Good luck... GUSTO
Old Nov 26, 2012 | 10:55 AM
rponfick's Avatar
rponfick
If your valve covers have the dripper metal thingy welded to the underside, sometime you can just hit them with a hammer to move them down a bit. Not sure if that is where your's are rubbing.
Ralph
Old Nov 28, 2012 | 03:41 AM
69small block
Default roller rockers
Thanks for input guys I have morso tall covers felpro gaskets the rubber ones. some of the rocker arms rub a little on the carb sibe of valve covers not sure what spacers these rocker arms are harland sherp I believe
Pita anywayI biought the moroso covers as they were suppose to be the largest covers for alum. ockers arms
Old Nov 28, 2012 | 03:48 AM
69small block
thanks for the help will ck them out
Old Nov 28, 2012 | 10:32 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I bought the tall Proform cast aluminum vv covers and most of the rockers were contacting the vv cover like yours. I took a dremel tool and just ground off a bit of the vv cover where they were making contact.
To alum roller rockers
