Poly bushing comparison
Old Nov 26, 2012 | 12:53 PM
Mgrad92's Avatar
Mgrad92
Default Poly bushing comparison
I've decided to rebuild my suspension with polyurethane bushings.
(I know there is always a debate between rubber and poly and some people will disagree with my choice, but that's not the point of this thread.)
My question is: Is there a particular manufacturer who is considered to be better than others when it comes to poly bushings? How do I avoid the junk out there?
Old Nov 26, 2012 | 12:55 PM
Corey_68's Avatar
Corey_68
I used energy suspension, no complaints.
Old Nov 27, 2012 | 07:42 AM
muskegonbrake's Avatar
muskegonbrake
Supporting Vendor
We have handled Energy Suspension and Prothane, both quality brands. We currently stock Prothane and our customers have been very satisfied with it.
Andrew
800-442-0335
http://www.muskegonbrake.com
Old Nov 27, 2012 | 09:06 AM
wcsinx's Avatar
wcsinx
Go with Energy Suspension. I know from personal experience that they do actually tune the durometer (hardness) rating of their bushings to the specific application. Their T-arm bushings for example are noticeable softer than their A-arm bushings.
It's the guys that go with the mystery off-brands that always tell you that polys are all hard as rocks and crack apart etc. etc. etc.
Old Sep 7, 2013 | 01:52 PM
wpmjr's Avatar
wpmjr
is ecklers a bad source for these?
Old Sep 7, 2013 | 03:11 PM
TimAT's Avatar
TimAT
No, ecklers is not a bad source. But you will pay. I got the full Energy Suspension set from Summit for $175 IIRC. All the front bushings, T/A bushings, all the sway bars (f&r), differential front cushion and a trans mount.
Old Jul 30, 2019 | 10:49 AM
svo855's Avatar
svo855
Navigator
I have I have run Del-A-Lum bushings on more cars then I can count; both on clients cars and my own; not once have I been unhappy with the ride.
Energy suspension runs 70 or 88 durometer urethane for the majority of their bushings. They don't do custom tuning per se.
Old Jul 30, 2019 | 11:44 AM
cv67's Avatar
cv67
St. Jude Donor '05
polygraphite>urethane
Old Jul 30, 2019 | 07:12 PM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
6 year old thread...
Old Jul 30, 2019 | 08:23 PM
svo855's Avatar
svo855
Navigator
Silly me. It linked to another post and I thought it was hey current thread.
Old Jul 31, 2019 | 10:51 PM
dedodson's Avatar
dedodson
4th Gear
I am working on my 89 installing new fuel lines. While having it all torn apart, I decided to replace all the bushing and went with superpro. They all installed easily except for the batwing bushings which were a little more work, but I did not remove it completely from the car. It would probably be much easier if removed and done with a shop press. I do not have mine back on the road yet, so I cannot comment on handling
I bought mine from https://www.corvettepartscenter.com/. They are the individuals who worked with superpro to get the bushings designed and made for the C4. There is a You Tube video from these guys. Just search superpro and you should find it.
Old Aug 1, 2019 | 01:31 PM
F4Gary's Avatar
F4Gary
I hope you didn't go poly for the rear strut rods as they need some give since they twist when the suspension is going up and down.
To Poly bushing comparison
